3p hitch lower lift arm attachment bolts - replace with pins & clips?
   / 3p hitch lower lift arm attachment bolts - replace with pins & clips? #11
Generic pins...
These come in three different strengths equal to SAE bolts...
No color or black is a grade 2 (5.8M) (74,000 PSI)
Red painted pins are grade 5 (8.8M) (120,000PSI)
Blue painted pins are grade 8 (10.9M) (150,000 PSI)
https://www.extension.purdue.edu/extmedia/ppp/ppp-94.pdf
Dale
   / 3p hitch lower lift arm attachment bolts - replace with pins & clips? #12
Red are fairly common at least in my area. They are available in a wide range of diameters and lengths. While I would be hesitant to use for the backhoe based on what the dealer told you, I can see no issue with using them for the 3 PH arms.
   / 3p hitch lower lift arm attachment bolts - replace with pins & clips? #13
Perhaps a little off topic but---
I keep a cluster of aluminum wire (from local Hydro truck) to 'safety wire' all my clips, hairpins etc in place.
Has worked out well 4 me.
Got fed-up losing pins!
2015 DODGE RAM 1500 CREW CAB TRUCK (A51406)
2015 DODGE RAM...
2002 FREIGHTLINER FL70 DUMP TRUCK (A51406)
2002 FREIGHTLINER...
2005 Isuzu NPR Venco VC516 Landscape Dump Truck (A53422)
2005 Isuzu NPR...
CUSHMAN HAULER 1200 GAS GOLF CART (A51406)
CUSHMAN HAULER...
2001 MACK CX SLEEPER (A54313)
2001 MACK CX...
2013 Ford F-550 Ext. Cab 4x4 Auto Crane 6406H 6,400LB Crane Service Truck (A53422)
2013 Ford F-550...
