3p hitch lower lift arm attachment bolts - replace with pins & clips?
   / 3p hitch lower lift arm attachment bolts - replace with pins & clips? #11
Generic pins...
These come in three different strengths equal to SAE bolts...
No color or black is a grade 2 (5.8M) (74,000 PSI)
Red painted pins are grade 5 (8.8M) (120,000PSI)
Blue painted pins are grade 8 (10.9M) (150,000 PSI)
https://www.extension.purdue.edu/extmedia/ppp/ppp-94.pdf
Dale
   / 3p hitch lower lift arm attachment bolts - replace with pins & clips? #12
Red are fairly common at least in my area. They are available in a wide range of diameters and lengths. While I would be hesitant to use for the backhoe based on what the dealer told you, I can see no issue with using them for the 3 PH arms.
   / 3p hitch lower lift arm attachment bolts - replace with pins & clips? #13
Perhaps a little off topic but---
I keep a cluster of aluminum wire (from local Hydro truck) to 'safety wire' all my clips, hairpins etc in place.
Has worked out well 4 me.
Got fed-up losing pins!
2017 CATERPILLAR 249D SKID STEER (A52705)
2017 CATERPILLAR...
KUBOTA M108S TRACTOR (A51406)
KUBOTA M108S...
2019 CATERPILLAR 299D2 SKID STEER (A52705)
2019 CATERPILLAR...
48" WIDE WOODEN STAIRCASE W/ METAL RAILING (A54757)
48" WIDE WOODEN...
2016 Ford Fusion S Sedan (A53424)
2016 Ford Fusion S...
UNUSED EINGP F10 - 10' WROUGHT IRON SITE FENCE (A54757)
UNUSED EINGP F10 -...
