3M Headlight Restoration Kit
/ 3M Headlight Restoration Kit #1
EagleTDL
N Alabama
Kubota BX-25
I followed Soundguy's 3M Headlight Restoration Kit thread with great interest, the Spousal Unit's '04 4-Runner's lens were pretty yucky at that time. Based on what I read, thought I would give it a try. Pics and commentary as follows...
First pic is of the kit itself... Gold 500 grit discs, white 800 grit discs, gray 3000 grit disc, orange buffing pad, rubbing compound and the disc/pad holder. Instructions suggest using a 1200-1600 rpm drill, I'd certainly suggest using a plug-in drill. I'm sure a battery powered one will spin fast enough, but unless you have brand new batteries, I don't know if they'll last long enough to complete the process on two lenses?
2nd and 3rd pics are of the headlights themselves... You can see they aren't completely yellowed, but pretty spotty and getting hazy. Will only show the left lens from here on out, the lighting in the garage was a little better on the left side of the vehicle. And forgive the sharpness of the photos, next cell phone will have image stabilization on the camera!
4th pic is after using the 500 grit pad. Mental note to self: Use the masking tape! The drill "hopped" twice on me during the whole process and if the masking tape wasn't there, I'd have been using this stuff to clean up some clear coat... :ashamed:
Have some paper towels handy, you can use them to wipe the dust off and see what you've missed. You know you're done with the 500 pad when 1) your sanding dust turns white (the first couple of passes were really yellow, which makes sense) and 2) you don't have any shiny spots left on the lens. At this point, you've gone too far to turn back! :laughing:
5th pic is after using the white 800 discs. A handheld shop light is really useful here, you can use it to see if you have any big scratches left. You'll know what I'm talking about as you go through the process. When you've gotten all the coarse scratches out, you're ready to go to the next step.
#6 is after using the gray 3000 pad... I kept both the pad and lens wet with a spray bottle through this step. I'd go across the lens, wipe, inspect and repeat until I thought I'd gotten all the 800 scratches out of the lens. The instructions talk about this step making a "slurry" if you are doing it right. Yep, it sure does! It also slings the slurry all over the place, which the instructions fail to mention... Be prepared to wash 1) the car afterwards 2) your clothes afterwards and 3) mop the floor afterwards! Pair of safety glasses aren't a bad idea here. You'll know you're done with the step when you aren't making a white slurry anymore. Your water will just disappear as it evaporates from the heat of the pad.
#7 is after the first application of buffing compound. I soaked the buffing pad in water and wrung it out before the first use. This contributes to some splatter in the process, but I didn't want the pad to get hot and smear the plastic. Used about a quarter-sized dollop of compound, would rather use too much as opposed to too little at this point. You can see that it has cleared up quite well.
Last pic... 2nd pass with the buffing compound, about a dime-sized amount this time. This pass really did the trick! Really cleared the lens up... If you get your eye on a sharp angle on the lens you can still see a slight bit of haze, but I think you need a finer grade of rubbing compound to get that out and I didn't have any.
Overall, I'm really pleased with the outcome and Momma is really happy! And you all know what that means... Thanks again, Soundguy, for originally posting this, good stuff!
Eagle
Excellent write-up. Thanks.
Welcome! If it wasn't for you guys on this site, wouldn't have known anything about the product. "Back at'cha" as they say... :)
/ 3M Headlight Restoration Kit #4
Nice job posting it. My son did his 97 ford, and you could not even see the bulbs. Now they are restored too, I wonder just how many times it will work? It took all the stuff the first time..
/ 3M Headlight Restoration Kit #5
depends on how bad your lenses are, though i doubt you get more than 2 full uses.. and I know they don't give you enough rubbing compound for more anyway.
I bought an extra bottle.
since I originally got the 1st kit, I've went ahead and done both my 99 fords, my 98 dodge, and my wife's 2000 yukon.
as eagle's excelent posting and write up shows, the results are 'clear' ( pun intended)
my 2 fords were nearly frosted over white!! now they look 90% at least like new.
mega ditto on the tape.. I used the wide 2" tape as that was what I had for my tractors when masking.. it helps prevent 'oops' situations.. and yep.. it makes everything dirty.. poly carbonate dust.. and splatter from buffing compound..
soundguy
/ 3M Headlight Restoration Kit #6
The way to fix your foggy or faded headlights once and for all is to wet sand them with 800 and then spray two coats of automotive clear coat on them. I use SPI clearcoat for all my projects and restorations.
The reason your headlights look the way they do is because the UV light has gotten to the plastic. Buffing will not add UV protection, but clearcoat will. Any other method of headlight "restoration" will need to be repeated about once per year, due to UV deteroration.
...since I originally got the 1st kit, I've went ahead and done both my 99 fords, my 98 dodge, and my wife's 2000 yukon.
soundguy
Hey Soundguy, where did you pick up the extra sanding discs? Or did you improvise for the later vehicles? Thanks!
/ 3M Headlight Restoration Kit #8
improvised by using same/similar grit media.
soundguy
/ 3M Headlight Restoration Kit #10
My son is finishing up his auto body program and they use painters plastic to cover the front of the car and then cut out and tape around the headlights, wet sand them with 2,000 grit, compound them then follow up with swirl mark remover then 2 coats of Teflon based wax. I was surprised at the results.
/ 3M Headlight Restoration Kit #11
i found a uv coating and lense polish at the local auto store. i applied it to my lamps after lettingthem dry.. goes in in 2 coats and cures decently fast... adds a nice seal to the lamp they you just ground on.
spray on, wipe off.. re apply about every 2m or so.. generally lasts thru at least 1 good washing.
least that's how it's holding on my vehicles.
good combination with the restoration polish job.
i guess if I knew how to shoot clear coat.. i might try that too.. :)
/ 3M Headlight Restoration Kit #12
It never ceases to amaze me what one finds on TBN.... excellent write-up, EagleTDL. Soundguy, I'll have to check out your thread as well!
So far my Jetta's lenses are holding up well, but I figure it's only a matter of time. Nice to see those lens restoration products actually work!:thumbsup:
/ 3M Headlight Restoration Kit #13
Excellent point!! Does this kit have a UV protectant? I got my Jeep headlights crystal clear again and within 6 months they were back to dingy yellow.
/ 3M Headlight Restoration Kit #14
That's what I've done with very good reults....Might try the 3M on the new to me 97 Ford MH...Headlights are just starting to yellow. Not too bad yet.
When I get it out of the mine, I'll give it a try.
/ 3M Headlight Restoration Kit #15
if just starting to yellow, try just the rubbing compound, forget the higher grit steps.
I polished a buddies lenses that were just starting to have, usuing jus tthe buff compound and worked great.. then once cleaned up we added the uv protectant spray. made it even better.
uv spray came from autozone.. was about 9$.. though thay had a couple different brands from 5$ or so and up
soundguy
UNUSED WOLVERINE HYD SCREENING BUCKET (A64281)
UNUSED WOLVERINE...
CASE TV370 SKID STEER (A62129)
CASE TV370 SKID...
STIHL HT131 POLE SAW (A62613)
STIHL HT131 POLE...
2017 NISSAN NV2500 4x2 VAN (A59911)
2017 NISSAN NV2500...
Headsight Autopilot Kit for Claas (A63117)
Headsight...
2016 International WorkStar 7500 T/A Dump Truck (A61573)
2016 International...
