3D Printed Dash Panel Decals
/ 3D Printed Dash Panel Decals #1
npalen
Elite Member
Beloit, KS
Kubota B9200 HSTD and Mahindra 3015
I printed these with PLA filament to replace the originals which had succumbed to UV. The originals were all international symbols but will go with all text for these replacements. I don't particularly care for the international symbols as some of them are simply not intuitive and make no sense to me.
The decals are 1/32" thickness with 1/32" thickness embossed text. Will probably try using automotive contact adhesive for bonding to the dash.
/ 3D Printed Dash Panel Decals #2
Looks pretty cool. I have absolutely no idea how to do 3d printing.
I suppose a 3D printer could be described as similar to any computer printer except its usually much taller to accommodate the 3rd dimension and uses plastic filament in lieu of ink to produce the part. The 3rd axis is the Z which creates the thickness of the part layer by layer with the code output by software called a "slicer" which defines the layers by inputting 3D computer created models.
The filament, which comes in a coil similar to weed-eater string, is fed thru a heated extruder which produces a stream of molten plastic about 1/64" (.4mm) in diameter which is distributed layer by layer with the X and Y axis printer movement.
There are hundreds of thousands of 3D models available for free downloading off the internet but the real creativity comes from learning and using 3D CAD on the computer.
/ 3D Printed Dash Panel Decals #4
We are using FreeCAD v22 in the Yanmar community. It's workbench based, yet free.
Very cool emblem and construction method!
I used ProE for about 10 years prior to retiring and started using the free version of Fusion 360 in the last year or so.
Would be interesting to have a thread where folks could show what they've printed for things of TBN's areas of interest. I'm amazed with ideas that folks come up with for utilizing the technology.
/ 3D Printed Dash Panel Decals #6
With several of the Yanmar/Deere compacts from the 70s, 80s,90s, parts suppliers have 3D printed now the dash, grills, emblems, and such. With 3D print on demand, little has to be stored in a warehouse hoping someday it will be ordered.
The way the emblem was done, thoughts on how it has to be painted to match the original in diecasted aluminum and painted.
I loved Pro-E WF5 and earlier. Today I'll run to the hills seeing creo. Creo now has a nickname called Crap-o.
I've dabbled in Fushion-360 it has some of the SolidWorks feel to it. Nice enough.
/ 3D Printed Dash Panel Decals #7
I printed some f 350 emblems and they have survived the sun the last 6 years
Currently have a creality cr-6max on a octoprint setup
Do you remember the type of filament you used? I've heard that PLA stands up fairly well outdoors but I probably should use ABS or ASA for UV resistance on these dash decals.
/ 3D Printed Dash Panel Decals #9
Cheap hatchbox PLA I believe
It was printed 100% infill
/ 3D Printed Dash Panel Decals #10
Very nice, good workmanship on a good idea.
/ 3D Printed Dash Panel Decals #11
There are hundreds of thousands of 3D models available for free downloading off the internet but the real creativity comes from learning and using 3D CAD on the computer sticker maker.
I was just curious how many of you use decals to detail your dashboards? I use the ones from BMCP whenever he has one for a kit I just bought. For a little over $2, I think they add a very nice touch to the interior! But, unless they are part of the kit's decal set, I rarely ever see them mentioned in WIP threads. I would like to know how many of you use them, or, if you don't, why not?
2022 Mac Trailers 48ft. T/A Walking Floor Trailer (A61573)
2022 Mac Trailers...
2023 CATERPILLAR 289D3 SKID STEER (A62129)
2023 CATERPILLAR...
KOMATSU PC88MR-11 EXCAVATOR (A65053)
KOMATSU PC88MR-11...
New/Unused AGT Industrial SDA-140T Track Loader (A65579)
New/Unused AGT...
LMC Nitrogen Applicator (A62177)
LMC Nitrogen...
2014 Freightliner Bucket Truck (A63689)
2014 Freightliner...
