3910 Power Steering Fluid Help
   / 3910 Power Steering Fluid Help #1
stickbowman
Whitesburg, GA
Kubota
I have a new to me 3910 and the power steering reservoir appears to be low. The manual I have says use Ford M-41 fluid. Any idea if M-41 is available or what substitute I should use??
Thanks!
   / 3910 Power Steering Fluid Help #2
Mine has a slow leak. I go to Oreilley's and buy power steering fluid.
I don't think the tractor cares. Might be noticeable during cold temps.
Let us know what you decide and how it works for you. :)
   / 3910 Power Steering Fluid Help #3
Use the same hydraulic oil you use in the transmission and rear axle/hydraulics. Needs to meet NH 134 specification.
I had thought about that but read that power steering fluid for cars destroys the seals, not sure how true that is...
Thanks It my manual it says use Ford M-134 in the trans and Hydraulics and to use the Ford M-41 in the power steering... I also read about someone using UTF ...
I can't seem to find any info on these old Ford fluids anywhere...
   / 3910 Power Steering Fluid Help #6
It is obsolete and replaced by 134.
   / 3910 Power Steering Fluid Help #7
Thanks!
Somewhere in one of my 3910 manuals it says to use the same fluid you use elsewhere in the tractor. That smells of 134 ABC but I put 134D in my main sumps when changing so I put it in there too.....better oil than ABC. I had the D (J20C is the popular posted spec for that oil) because I have wet brakes and had it on hand for my Bransons.
   / 3910 Power Steering Fluid Help #8
   / 3910 Power Steering Fluid Help #9
I smell a rat, old wives tale, somebody with their head buried, mouth running and brain in neutral, blabbing to hear them selves blabbing, ..........where's their reference to such?
   / 3910 Power Steering Fluid Help #10
Automotive power steering fluid is thinner than the spec fluid and MAY leak easier and sooner. It pretty much begins and ends there. Some owners use it without any issues.
TAKEUCHI TL8R2 SKID STEER (A51242)
TAKEUCHI TL8R2...
2014 Dynapac CC4200 Tandem Vibratory Roller (A51039)
2014 Dynapac...
2017-2023 Ford 4x4 Super Duty Pickup Bed (A49461)
2017-2023 Ford 4x4...
2019 Allmand Night-Lite V-Series S/A Towable Light Tower (A49461)
2019 Allmand...
2005 WINNEBAGO WORKHORSE W22 RV (A50854)
2005 WINNEBAGO...
2001 STERLING WATER TRUCK (A51243)
2001 STERLING...
