3910 Power Steering Fluid Help
   / 3910 Power Steering Fluid Help #1
stickbowman
Whitesburg, GA
Kubota
I have a new to me 3910 and the power steering reservoir appears to be low. The manual I have says use Ford M-41 fluid. Any idea if M-41 is available or what substitute I should use??
Thanks!
   / 3910 Power Steering Fluid Help #2
Mine has a slow leak. I go to Oreilley's and buy power steering fluid.
I don't think the tractor cares. Might be noticeable during cold temps.
Let us know what you decide and how it works for you. :)
   / 3910 Power Steering Fluid Help #3
Use the same hydraulic oil you use in the transmission and rear axle/hydraulics. Needs to meet NH 134 specification.
I had thought about that but read that power steering fluid for cars destroys the seals, not sure how true that is...
Thanks It my manual it says use Ford M-134 in the trans and Hydraulics and to use the Ford M-41 in the power steering... I also read about someone using UTF ...
I can't seem to find any info on these old Ford fluids anywhere...
   / 3910 Power Steering Fluid Help #6
It is obsolete and replaced by 134.
   / 3910 Power Steering Fluid Help #7
Thanks!
Somewhere in one of my 3910 manuals it says to use the same fluid you use elsewhere in the tractor. That smells of 134 ABC but I put 134D in my main sumps when changing so I put it in there too.....better oil than ABC. I had the D (J20C is the popular posted spec for that oil) because I have wet brakes and had it on hand for my Bransons.
   / 3910 Power Steering Fluid Help #8
   / 3910 Power Steering Fluid Help #9
I smell a rat, old wives tale, somebody with their head buried, mouth running and brain in neutral, blabbing to hear them selves blabbing, ..........where's their reference to such?
   / 3910 Power Steering Fluid Help #10
Automotive power steering fluid is thinner than the spec fluid and MAY leak easier and sooner. It pretty much begins and ends there. Some owners use it without any issues.
REYNOLDS 100 - 8 YARD PULL TYPE SCRAPER PAN WITH DRAWBAR (A52128)
REYNOLDS 100 - 8...
2019 TOYOTA 8FGCU25 PROPANE FORKLIFT (A51222)
2019 TOYOTA...
2017 Yamaha VX1050B Deluxe Jetski (A50324)
2017 Yamaha...
CATERPILLAR 140M VHP MOTORGRADER (A51242)
CATERPILLAR 140M...
Great Plains Nutri-Pro NT-30 Nh3 Applicator (A50514)
Great Plains...
2003 Honda ATV (A50324)
2003 Honda ATV...
