375 jd hoe question
/ 375 jd hoe question #1
tjjr
NJ
JD 3520
I just purchased a new jd 375 backhoe. I noticed that when i let the hoe sit 1 or 2 days without being used the stabilizers start to drift down. Is this normal? :confused:
Thanks
/ 375 jd hoe question #2
Most hydraulics, if left "up", will slowly drift down over time. I think the operative word here would be,..."slowly". Stabilizers are no different, IMO at least. Then depending on the circumstances and the place and whats close that might be damaged, you either put them down or tie them up.
Perhaps I should leave this to someone who "knows" this particular 375 model a little more intimately as each has its own idiosyncrasies.
This part should be under "safety", but of course "never" leave anything "up" where kids are apt to touch levers and crush one another! You likely know all that stuff, but just a reminder to those that may not.
Good luck with your new machine,...should be fun!
. . . tug
/ 375 jd hoe question #3
Welcome to TBN TJJR:D
The leakdown is perfectly normal. A short chain or strap between the two will solve your problem.
/ 375 jd hoe question #4
what kenny said.I put and chain and hook on to hold them up when stored off tractor.
/ 375 jd hoe question #5
The only thing I would add is to look if there is any fluid on the floor under the stabilizer. I had a slow leak on the top of the stabilizer hyd cylinder (o-ring?) and my dealer replaced the entire cylinder under warranty.
2016 Nissan Titan XD Crew Cab Pickup Truck (A66736)
2016 Nissan Titan...
2017 Ford Explorer AWD SUV (A66738)
2017 Ford Explorer...
ENCLOSED OPERATOR CAB (A68842)
ENCLOSED OPERATOR...
2005 MACK VISION (A67714)
2005 MACK VISION...
PORTA POTTY (A67714)
2007 AMERITRAIL  GOOSENECK TRAILER (A67714)
2007 AMERITRAIL...
