3725C AC question
/ 3725C AC question #1
birdmandave
Weston, CO
Branson 3725C
Finally cranked on the a/c last week on the 17 3725c for the first time. Felt just like the heat in the winter. I bought one of those diy test and charge cans and it worked great for day. Anyone have any problems with new ac system?. I suspect I have a leak? If unable to fix easily at home then I will take to dealer for warranty. Gets pretty toasty in that cab, but the 3 window ac worked great. Thanks
/ 3725C AC question #2
So I'm confused is your AC working or did the one can just fix it for a bit?
I'm not sure how much these systems hold but I just put 3 cans in IH 7230 and it needs at least one more.
I use mine in the Branson 8050 in the winter to defog the windows AC on and temp 3/4 of the way up so it gets exercised that way.
I've always heard that not using them was the worst thing to do.
/ 3725C AC question #3
Just used mine this afternoon for the first time this season. Worked just fine. Was 90+ F outside when I started, and I was quite comfortable the whole time I was in the cab mowing.
/ 3725C AC question
Yes, it worked for a day after using the can. I don’t know if these systems are charged from the factory or typically a dealer set up and I have no idea how long it sat on the dealer lot. I can tell you the ac compressor was not spinning until I shot in the can. I’m willing to invest another $30 for another can, but also don’t want to waste it if I have a leaking seal. This may test the Branson warranty.
/ 3725C AC question
That’s what I was hoping for but ended up a little sweaty.
/ 3725C AC question #6
The R134 I picked up at NAPA varied a bunch in price;
one with oil and seal additives and stop leak was $20+,
the ones with just the Freon were $8.
I know that when ours get low it may take a couple of cans for the clutch low pressure switches to make.
Your system should have been filled from the factory, I doubt the dealer would have checked it unless they noticed it not working.
I would holler at my dealer and give him the choice of coming out and servicing it on site or providing you a couple-3 more cans.
It would be a royal pain to have to pay to transport the tractor back to him, I don't know how many miles are involved, or if you can haul it.
/ 3725C AC question
I agree with contacting dealer, don’t want to keep band aiding if it’s a compressor or evaporator problem. Come Tuesday I’ll be speaking with dealer early. I do have the ability to haul it but won’t let them know that. It’s a good hour drive. Thanks
2022 Deere 325G (A62180)
2022 Deere 325G...
Container W/Side Door & Windows (A62183)
Container W/Side...
RIG MATS (A63569)
RIG MATS (A63569)
2004 AGCO Gleaner 3000 Corn Header (A61307)
2004 AGCO Gleaner...
10 Chains & 5 Binders (A62183)
10 Chains & 5...
Case Axial-Flow Combine Wheels NO RESERVE (A63118)
Case Axial-Flow...
