Buying Advice 3725 Branson Width?
/ 3725 Branson Width? #11
Also consider that you can have the tires and rims "adjusted" to a wider stance than how the tractor "normally" is set up. When I bought my 4020 I had the tires moved to the widest setting for stability. With R4 tires outside to outside is 78 inches. That opens up a couple possible issues with attachments as now it takes an 84 inch implement to get outside the tire width. An 84inch box blade behind a 40hp tractor can be a big pull at times for me depending on material and how much I'm moving. Just things to think about.
/ 3725 Branson Width? #12
If you are contemplating doing any snow removal, you may want the narrower tire spaced out the widest possible in order to install tire chains, without tearing things up.
Looking at the 20 series (3520, etc) brochure:
IND10 rears are 43x16-20
IND20 rears are 420/70x24
IND25 rears are 16.9x24
The 25 series 'sales features' PDF on the Branson website (I don't have a 25 series brochure) shows 420/70x24-6 rears for all tractors (same as the IND20 option in the 20 series brochure). Branson surely allows IND10/20/25 type options for the 25 series like they do on the 20 series (as Eric said). Also like Eric said, only the IND10 rears have the welded one piece wheel.
http://www.bransontractor.com/Branson/files/34/34fcfe5a-cd28-41ea-900b-7692f0043e5c.pdf
http://www.bransontractor.com/Branson/files/80/80c1fca8-94e7-4c8f-ab66-4581e3a73dd4.pdf
The 3725H arrived at the Dealership yesterday so I drove out to take a look and measure the width. I thought I would post on this thread so other potential buyers have the info. The tractor has the standard IND20 tires on the rear and the width outside to outside is 69"
/ 3725 Branson Width? #14
They may come set up on the narrowest position to take less room when shipping.
/ 3725 Branson Width? #15
Are the large IND30 tyres available on cab tractors? I've only seen them with the IND20, and they seem to be filling up the wheel well for cabbed tractor, maybe this is due to more needed clearance for cab doors, etc.
/ 3725 Branson Width? #16
Yes they are available. They look really good with em on
23" QUICK ATTACH EXCAVATOR BUCKET (A60429)
23" QUICK ATTACH...
Zero Turn Mower (A59231)
Zero Turn Mower...
CATERPILLAR 255 SKID STEER (A52709)
CATERPILLAR 255...
2006 International 7400 SFA 6x6 Bucket Truck (A60352)
2006 International...
Wacker Neuson PT2 Water Pump (A59228)
Wacker Neuson PT2...
2011 GROVE TMS900E TRUCK CRANE (A58214)
2011 GROVE TMS900E...
