3720 Issue
/ 3720 Issue #1
NYBOB
Maine NY(Binghamton area)
2007 JD 3720
I have a 3720 that started to heat up a little today for the first time....did not get in the red on the gauge. I was mowing a field with my finish mower and it was really thick. It was about 90 degrees also....I think the tractor was working hard but never noticed this before. It sent out a code of EEnPH1...the last one could be an I.
I stopped mowing and let the turbo cool down a little and turned it off. I turned it back on later and it worked fine and the code was off.
Do I need to have it looked at by the dealer?
Thanks
Bob
/ 3720 Issue #2
Verify that your coolant is full, to the operating range. Check your radiator & screen and clean them if necessary.
If you have enough coolant, and if the radiator and/or screen are not clogged with dust, it should be able to handle working in 90 degrees, IMHO. If either of these needed attention, that was probably the source of the problem.
/ 3720 Issue #3
My tractor coolant resivoir is always at the full mark cold or hot for some reason. It never expandable or retracted. Weird
/ 3720 Issue #4
That sounds a little strange. Have you removed the radiator cap to see if radiator is in fact full? You may have a damaged hose connecting the reservoir to the radiator.
/ 3720 Issue #5
Mine overheated once too, and I was at first confused because the reservoir was at the correct mark. So when it cooled down, I removed the radiator cap. Couldn't see any coolant at all. For some reason, at some point a low radiator won't pull fluid from the reservoir. I topped up the radiator, the problem's never come back.
//greg//
/ 3720 Issue #6
Probably the grills covered by debris..not an uncommon occurence when mowing.
Suggest you buy a 2" paint brush and trim the bristles down to about 3/4's of an inch. That works quite well for cleaning the grills in the field.
/ 3720 Issue
I had checked all the items suggested except for taking the radiator cap off. I will check it out in the morning.
I will let you know how I make out.
Thanks everyone...
/ 3720 Issue #8
Thanks guys. I'll have to check my radiator later. I have been mowing with a/c and the temp gauge has been in the middle. I rrmeber topping it off almost 2 months ago. Ill check again
/ 3720 Issue #9
i checked the radiator. it is full. i also squeezed the hose running to the cab heater and also i squeezed the water pump hose. The coolant wants to pump out of the radiator opening. so it doesnt seem like there is any obstructio. I dont know why my overflow doesnt expand or retract with temperature fluctuation. Do you guys?
/ 3720 Issue #10
Have you checked with a temp gun? Possible the gauge is off?
If anything was plugged completely something would have to blow eventually.
My overflow is almost always empty but the radiator is always full.
There could be some restrictions in the radiator causing it not to cool efficiently. Also in my experience the screens in front of the radiator does not block everything. Hose out the radiator from the engine side.
/ 3720 Issue #11
Ok ill have to check the temp with my gun this week sometime
/ 3720 Issue #12
Same on my 2007 3720 cab tractor. The overflow tank coolant is always on full mark -- hot and cold. I've checked the radiator and it is full as well but I've never had any engine over heating issues after over 400 hrs on the meter. The A/C was weak twice -- once due to a bad roof seal and on another occasion due to debris in the condenser in front of the radiator, still no engine over heating.
I wonder if your engine thermostat will not open all the way!!
/ 3720 Issue #13
anyone take some temp readings before with there gun? i have a cheap little unit i dont trust much but i cant get any readings anywhere over 157 degreees. tried water pump and etc. what readings are you guys getting. this is a new machine with 72 hours ******. hahahhah. even so, i wont send it in until i hit 100 hours cause thats when its getting a full fluid change
2007 HEIL TRAILER (A65643)
2007 HEIL TRAILER...
2021 Felling FT-45-2LP 29ft. 26 Ton Tag Trailer (A64194)
2021 Felling...
3pt Hitch Receiver (A62679)
3pt Hitch Receiver...
2012 Chevrolet Colorado Crew Cab Pickup Truck (A64194)
2012 Chevrolet...
Bainbridge,Georgia (A65640)
Bainbridge,Georgia...
2015 VANTAGE TRAILER 3 POD PNEUMATIC TRAILER (A65643)
2015 VANTAGE...
