3720 Hydraulic Problem
/ 3720 Hydraulic Problem
Called the dealer.
Missing O-Rings on the filter cover.
/ 3720 Hydraulic Problem #12
That would do it. Glad you finally figured it out. I have not changed the filter on 3520 yet. I'll have to pay special attention to that.
Sincerely, Dirt
/ 3720 Hydraulic Problem #13
Hi
Did you clean out the suction screen? Is it proberly reinstalled? Sounds like some air in the system to me also. I've not had that happen to any of my JD's doing fluid change for the universal sump.Perhaps with the loader on and connected, tractor off, crack one of the metal fittings to a hose going to the cylinders up front to let out the air. Start it for a second and bleed it. Shut it off and tighten the line. Stay away from the line when it leaks. Perhaps that will help get the air out.
Steve
2002 Frieghtliner Pressure Digger Truck (A55973)
2002 Frieghtliner...
2018 CATERPILLAR 420F2 BACKHOE (A59823)
2018 CATERPILLAR...
Case Titan 3530 (A61307)
Case Titan 3530...
2017 Dodge Charger Sedan (A59231)
2017 Dodge Charger...
2016 GMC Seirra Denali 1500 4x4 Crew Cab Pickup Truck (A60352)
2016 GMC Seirra...
Towable Chemical Applicator Sprayer (A59228)
Towable Chemical...
