3720 and round bales
/ 3720 and round bales #1
CWP37
Hill Country, TX
John Deere 5103 w/ 512 LDR
I know there are different size round bales. Who has a 3720 and do they handle round bales with the 3ph or FEL? Either or both or neither? Thanks in advance.
/ 3720 and round bales #2
I don't handle round bales with mine. But, from handling them in the past with other machines, I'd have to say I think it would handle one (900lb or so) but a larger frame tractor sure would do a better job. I just think these little machines get unstable and are not very efficient when working with large loads like this. Around here it is just too hilly that I would not enjoy carry a large bale out to the ring and lifting it up high enough to dump it over the fence without taking time to position myself just right. Most likely could do it, I'm just not sure have efficiently it can be done. Maybe if you didn't have too much to feed and could take your time.
But, I bet someone on the board here does work with round bales with a CUT and might can give you some actual experienced comments.
Deere does offer a bale spear for the loader, so apparently it is possible.
Chris
LS XR4046 Tractor with Front End Loader (A65579)
LS XR4046 Tractor...
2008 MACK CHU613 DUMP TRUCK (A63569)
2008 MACK CHU613...
New/Unused ATS T460 Mini Skidsteer (A65583)
New/Unused ATS...
2021 JOHN DEERE 324L WHEEL LOADER (A65053)
2021 JOHN DEERE...
2006 Utility Spread Axle Trailer (A62679)
2006 Utility...
Allis Chalmers WD45 Tractor (A66285)
Allis Chalmers...
