3616 grease fitting above front axle
   / 3616 grease fitting above front axle #1
jim3616
upper valley, nh
mahindra 3616
I'm having a difficult time pushing grease through the fitting above the front axle. I pulled the fitting and it's fully machined. Anyone having this issue?
   / 3616 grease fitting above front axle #2
I haven't.
   / 3616 grease fitting above front axle #3
On the front axle pivot? Those can be under tremendous pressure and at times won't take grease from the $10 auto store grease guns, but require the heavy duty high pressure grease guns. Try using the loader to lift weight off the front axle and give it a squirt.
   / 3616 grease fitting above front axle #4
Same problem with my 3016 and I am using so much pressure from my air grease gun its pushing off my clip on grease gun fitting. I pulled mine all apart and found it had grease and for the life of me I can't see the path grease is suppose to take.
   / 3616 grease fitting above front axle #5
My dealer said its tight tolerances making it difficult to push grease in. They said It's taking grease just really slow.
I'm finally pushing a small amount of grease - very tight tolerance
   / 3616 grease fitting above front axle #7
As Sysop says, if you have a loader, put the bucket down and lift the wheels off the ground, this make it easier to get grease in. If you don't have a loader then a heavy impliment ie box blade, on the 3ph to transfer weight off the front axle will help getting grease into the axle pivot.
Case-IH 165 Puma (A50120)
Case-IH 165 Puma...
2015 Ford Escape SUV (A50324)
2015 Ford Escape...
2017 Terex Warrior 1800 Screener (A50322)
2017 Terex Warrior...
2012 DRAGON 150BBL ALUMINUM VACUUM TANKER TRAILER (A52472)
2012 DRAGON 150BBL...
2009 IC Corporation PB105 School Bus (A51692)
2009 IC...
2025 Icon Electric Bike (A50324)
2025 Icon Electric...
