36 inch bucket
   / 36 inch bucket
Thanks for the advice i know another digger who uses a 4720 with a 36 inch bucket widened out 39 inch. He says works good he has a Bradco hoe on the tractor . He is a full time digger I work construction and digging is a side job in a few country cemetery 's . Up and till recently i dug by hand. I'm concerned about powering the large bucket to ;but keeping the hole wall's from coming in on the bottom and the moving back and forth is a pain in tight spots .
   / 36 inch bucket #12
I don't know an easy way to up load it, but I have a 39 page 110 tlb order code/ option/ complete specs pdf file and this was on it.
36-in. Bell Hole Bucket for John
Deere 110 TLB
This bucket allows the customer to create a wide straightsided
trench. These buckets are commonly used by cemeteries.
Note: Backhoe must be equipped with Backhoe Bucket
Mechanical Quick Coupler Interface.
This bucket has the following features:
• Quick couple hangers allow easy and clean installation
or removal of bucket in minutes.
• Heavy 3/4-in. by 5-in. cutting edge for long wear.
• Strong 1/2-in. wall torque tube at bucket top effectively
transfers digging effort to entire bucket.
• Six digging teeth for aggressive digging action. Teeth
are top-pinned for easy replacement.
• Large 3.7 cu. ft. (.10 cubic meter) rated capacity.
Order directly from:
C & P Attachments
8822 Apison Pike
Ooltewah, Tennessee 37363-8624
Phone: (800) 433-6404
Fax: (423) 396-3317
Email: c&p@cpbuckets.com
Note: This item will ship directly from C&P Attachments,
Ooltewah, TN. Approximate shipping weight is 235
bundle # 36009E-1
   / 36 inch bucket
Thank you I will check the numbers and the other information I got here. And let every body no what I fined out.
   / 36 inch bucket
Up date got my knew 36 inch bell hole bucket yesterday Digs a37 inch finished hole . Got it mounted today hope to try out soon.
   / 36 inch bucket #15
Glad to hear you got everything worked out!
If I recall correctly, I believe that JD makes a cemetery bucket for the 110, too. Thought it was listed in the WorkPro attachment section @ www.JohnDeere.com
AKfish
PALLET OF 1" HOSE (A58376)
PALLET OF 1" HOSE...
2016 Ford Escape SUV (A56859)
2016 Ford Escape...
2017 VOLVO VNL TANDEM AXLE DAY CAB (A59575)
2017 VOLVO VNL...
2017 Dodge Charger Sedan (A56859)
2017 Dodge Charger...
KUBOTA SSV65 OPEN STATION CAB (A52706)
KUBOTA SSV65 OPEN...
2005 Detroit Diesel 100DSEJB 138kVA 3-Phase Diesel Generator (A59228)
2005 Detroit...
