36 inch bucket
/ 36 inch bucket #1
Eddy g
Illinois
jd
Have Jd 110 tlb with18 inch bucket.Would like 36 inch bucket that i could widen to 39 inch for my grave digging side job. Did they make them for the 110? mine has quick attach bucket. Need to dig full width of grave.
/ 36 inch bucket #2
Also dig graves have a 4720 with a 485 hoe bought a bucket made for graves it's called a bell hole bucket or a cemetery bucket it gives a nice vertical wall and a flat bottom no getting in the hole it makes a nice neat grave
/ 36 inch bucket
Do you think i could get one for my 110
/ 36 inch bucket #4
Does the 110 use a proprietary mount? Google bell hole bucket or cemetery bucket, you'll find numerous hits. Seems they go out to 36".
/ 36 inch bucket #5
I don't know what's out there or what is offered in the way of specialty buckets, but a 39" seems a bit big for a 110 to run. But anything can be made/modified.
/ 36 inch bucket #6
Your gonna lose productivity with that size bucket if you found one. Stick with the bucket you have. You would dig 2 graves with an 18 inch bucket by the time you got finished with one with a 39 inch bucket. The only thing you will be able to heap is topsoil with that bucket. Once you get to virgin fill, you wont be digging anything. You will be exceeding the weight and power of that machine for the bucket to cut through anything
/ 36 inch bucket #10
Yes u can get a bucket for the 110 not sure the 110and the 27 & 35 mini share the same bucket set up so should have more options. The bucket I use is 36" wide with no issues cut off the outside tooth shanks and twisted them out to give a 38" width a little extra tooth ware but teeth are fairly cheap for theses buckets it is well worth the money for, the bucket it saves so much time.
/ 36 inch bucket
Thanks for the advice i know another digger who uses a 4720 with a 36 inch bucket widened out 39 inch. He says works good he has a Bradco hoe on the tractor . He is a full time digger I work construction and digging is a side job in a few country cemetery 's . Up and till recently i dug by hand. I'm concerned about powering the large bucket to ;but keeping the hole wall's from coming in on the bottom and the moving back and forth is a pain in tight spots .
/ 36 inch bucket #12
I don't know an easy way to up load it, but I have a 39 page 110 tlb order code/ option/ complete specs pdf file and this was on it.
36-in. Bell Hole Bucket for John
Deere 110 TLB
This bucket allows the customer to create a wide straightsided
trench. These buckets are commonly used by cemeteries.
Note: Backhoe must be equipped with Backhoe Bucket
Mechanical Quick Coupler Interface.
This bucket has the following features:
• Quick couple hangers allow easy and clean installation
or removal of bucket in minutes.
• Heavy 3/4-in. by 5-in. cutting edge for long wear.
• Strong 1/2-in. wall torque tube at bucket top effectively
transfers digging effort to entire bucket.
• Six digging teeth for aggressive digging action. Teeth
are top-pinned for easy replacement.
• Large 3.7 cu. ft. (.10 cubic meter) rated capacity.
Order directly from:
C & P Attachments
8822 Apison Pike
Ooltewah, Tennessee 37363-8624
Phone: (800) 433-6404
Fax: (423) 396-3317
Email: c&p@cpbuckets.com
Note: This item will ship directly from C&P Attachments,
Ooltewah, TN. Approximate shipping weight is 235
bundle # 36009E-1
/ 36 inch bucket
Thank you I will check the numbers and the other information I got here. And let every body no what I fined out.
/ 36 inch bucket
Up date got my knew 36 inch bell hole bucket yesterday Digs a37 inch finished hole . Got it mounted today hope to try out soon.
/ 36 inch bucket #15
Glad to hear you got everything worked out!
If I recall correctly, I believe that JD makes a cemetery bucket for the 110, too. Thought it was listed in the WorkPro attachment section @ www.JohnDeere.com
AKfish
2014 Ford F-350 Altec Service Truck (A66736)
2014 Ford F-350...
2020 ISUZU NRR 4X2 S/A 22FT BOX TRUCK (A59912)
2020 ISUZU NRR 4X2...
2021 CATERPILLAR 326 LONG REACH EXCAVATOR (A64279)
2021 CATERPILLAR...
2014 MAC FLAMELESS HEATER TRAILER (A67714)
2014 MAC FLAMELESS...
JOHN DEERE 5045E TRACTOR (A65057)
JOHN DEERE 5045E...
2000 PETERBILT 379(INOPERABLE) (A67714)
2000 PETERBILT...
