353HST Hard to shift into/out of 4WD HELP ?
   / 353HST Hard to shift into/out of 4WD HELP ? #1
astro1949
my 353HST is very hard to shift into and out of 4 wheel drive ---any help appreciated......
bob
   / 353HST Hard to shift into/out of 4WD HELP ? #2
I would like to help but to be honest I have never taken mine out of 4wd.
ok----whn it gts warmer, ill wd40 all the linkage and see if that helps----otherwise I'll just leave it in 4WD ---i cut grass and Brushhog --- sometimes the mud is hard to see, so I'll not have an issue if it's already in gear.......thanks,
bob
   / 353HST Hard to shift into/out of 4WD HELP ? #4
I've had to grease mine / use oil on the linkage. Solved the issue for me.
   / 353HST Hard to shift into/out of 4WD HELP ? #5
I always use lithium grease
2008 Volkswagen Passat Sedan (A51694)
2008 Volkswagen...
UNUSED RAYTREE RMPP680 HYD POST POUNDER (A51248)
UNUSED RAYTREE...
New/Unused CFG Industrial QK16R Mini Excavator (A51573)
New/Unused CFG...
(2) COLUMN PROTECTORS (A51248)
(2) COLUMN...
2016 Autocar Xpeditor T/A New Way Side Loader Garbage Truck (A51692)
2016 Autocar...
2009 Freightliner M2 106 MedTec Ambulance (A51692)
2009 Freightliner...
