3535 automatic PTO
/ 3535 automatic PTO #1
Mahindra3535
Conover, N.C.
2013 Mahindra 3535
Went to use PTO in automatic yesterday and it would not work. When I had tiller down on ground it was acting like I had the lift raised up. I assume it has to be electrical. Just curious if anyone else has experienced this.
/ 3535 automatic PTO #2
Have you used it successfully yet? Before this. I know these a toggle on the right side of dash that sets to run, auto and off I think and a button on the left side that starts it
Yes I used to be the auto function before. It worked fine last year. It has to be something electrical I would think.
/ 3535 automatic PTO #4
I've heard that the solenoid can get stuck. With roto off the tractor, turn the required switches on and give the PTO solinoid a tap with a wooden handled screwdriver.
/ 3535 automatic PTO #6
I don't know about your Mahindra, but on my Kioti there is a micro switch that the 3 pt. Lift handle engages that activates the PTO solenoid. I would not be surprised if yours is not similar.
2010 Rhodes AS3575-3 35ft. 75yd. Tri-Axle Aluminum End Dump Trailer (A66736)
2010 Rhodes...
2015 Grasshopper 725D 72in Zero Turn Commercial Mower (A68183)
2015 Grasshopper...
Heavy Duty Booster Cables (A64557)
Heavy Duty Booster...
2016 Ford Explorer AWD SUV (A66738)
2016 Ford Explorer...
2006 PETERBILT 379 (A67714)
2006 PETERBILT 379...
500 BBL FRAC TANK (A67714)
500 BBL FRAC TANK...
