3520 losing curl pressure on FEL
   / 3520 losing curl pressure on FEL #1
mschmader
The hydraulic cylinders seem to be losing pressure on the curl function of my front end loader on 3520. Why does this happen?
   / 3520 losing curl pressure on FEL #2
Does it do this with & without a loader in the bucket? Does your FEL have a regen valve?
   / 3520 losing curl pressure on FEL #3
Both of my curl actuators failed within 6 months of new on my 2010 3520.
Dealer advised this was normal, I explained that if I didn't hold full Px when bucket was loaded, it would dump the load by the time I hit the other side of the farm. I demanded that both cylinders be repaired or replaced. If you are out of the lengthy one year warranty , the cylinders are very easy to re-seal. Kits from jd in canada are expensive, you will find them cheaper else where I am sure.
   / 3520 losing curl pressure on FEL #4
A quick check is to remove the bucket, roll actuators full forward to dump position at idle, remove one tie bar bolt ( either side) have an assistant VERY SLOWLY, move the controls to curl position, at the same time, have a bar in the mount that attaches to bucket . If your actuator is bypassing, you will be able to hold the bucket mount with the bar. Be VERY CARFUL, as pressure rises the actuator will eventually retract, so keep your head out of the way of the bar. If you try this with the tie bar connected, a good cylinder will drive a bad cylinder and conceal the bad cylinder.
If you find one bad cylinder and don't repair it before working with a loaded bucket, you may have further problems down the road, like I did with my cracked loader arm .
   / 3520 losing curl pressure on FEL #5
If your talking about the cylinders not holding, you need the them replaced. Mine were junk from day 1. They first tried resealing them but ultimately wound up replacing them both under warranty. The bores must have been out of round. Anyway, heres a thread I started when I had the issue. Maybe this helps you out if its the same issue. The easiest way to see if its your cylinders bleeding out is to get the bucket level and raise it up a bit. Then disconnect the lines from the tractor.
Heres the thread
http://www.tractorbynet.com/forums/...361-legit-complaint-am-i-over.html?highlight=
   / 3520 losing curl pressure on FEL #6
Test them using the relief valve. If it will relieve, that means that both cyl is building up pressure.
Remove both cyl ends from the bucket.
Cap hoses from one cyl.
Retract the cyl still connected and remove the base end hose and make it retract some more.
If fluid still flows from the base end of the cyl, the cyl is bypassing and you need new seals or new cyl.
Test the other cyl.
Test them using the relief valve. If it will relieve, that means that both cyl is building up pressure. Remove both cyl ends from the bucket. Cap hoses from one cyl. Retract the cyl still connected and remove the base end hose and make it retract some more. If fluid still flows from the base end of the cyl, the cyl is bypassing and you need new seals or new cyl. Test the other cyl.
What is the relief valve?
   / 3520 losing curl pressure on FEL #8
The relief valve protects hyd system from pressure overloads. It should be set at a specified pressure. Relief valve opens when system psi is exceeded.
Where is it on the tractor?
   / 3520 losing curl pressure on FEL #10
It's probably located in loader control valve. What is your FEL model #?
2012 JOHN DEERE 10-INCH REAR WHEEL SPACER FOR 10 BOLT HUB (A53473)
2012 JOHN DEERE...
2020 CATERPILLAR 299D3XE SKID STEER (A52705)
2020 CATERPILLAR...
UPDATED INTERNET BUYER'S PREMIUM TERMS (A50775)
UPDATED INTERNET...
2018 International DuraStar 4300 Truck (A52377)
2018 International...
2013 BIG TEX BIG TEX (A53843)
2013 BIG TEX BIG...
2008 Isuzu NPR-HD Landscape Dump Truck (A53422)
2008 Isuzu NPR-HD...
