3520 John Deere wont move forward or reverse
/ 3520 John Deere wont move forward or reverse #1
snoopygarcia792
Bosque Farms,nm
JD3520
Hope someone has come across this problem and can help me. I have a John Deere 3520H 2005 model no cab tractor that is Hydrostat transmission. The tractor will not move forward or reverse. I canmove the shift lever to A, B and C positions with a slight detent. Check the seat, break switches all good. No Codes? With the machine off. I Pulled the X27 connector that goes to the forward and reverse solenoids, both had a resistance of 4 ohms. When the machine and either forward or reverse is pressed I get 0 to 3.8 vdc. So it looks like the pedal circuit is working. I tried getting the raw data using the display but my model doesn稚 seem to work. I am truly lost.PLEASE HELP?ust a side note the loader and PTO work fine? Can anyone tell me what voltage the forward/reverse solenoids operate at is it a square wave or just a dc voltage. What痴 suppose come out of the A2 electronic drive controller for these solenoids?
Thanks in advance SG792..
/ 3520 John Deere wont move forward or reverse #3
I have a PDF of the Tech manual you're more than welcome to
If wanted, shoot me your email
Joe
Thank you.I purchased the TM2137 and TM2138 service Manuals.They don't give you the fine details on the solenoids or the drive module that I need for further testing.
New/Unused Wolverine 72in Quick Attach Brush Cutter (A65583)
New/Unused...
GRILL GUARD FOR MASSEY FERGUSON TRACTOR (A64278)
GRILL GUARD FOR...
BRIGGS & STRATTON STORM RESPONDER GENERATOR (A64276)
BRIGGS & STRATTON...
Landhonor Quick Attach Tree Puller (A66285)
Landhonor Quick...
JOHN DEERE C6R36" CORN HEAD (A64278)
JOHN DEERE C6R36"...
2013 VOLVO VNL630 6X4 T/A SLEEPER TRUCK TRACTOR (A67147)
2013 VOLVO VNL630...
