3510 will not start
/ 3510 will not start #1
grunewald
St. Hedwig, Texas
Mahindra 3510
any quick suggestions, stopped tractor using fel in too high of gear, now it wont start. Turn key on and relay in front of radiator clicks, but nothing else happens. Have not really dug into it yet, wiring diagram is a nightmare. Tractor is only 5 months old, dont know if they will come out to house to check it, 10 minutes from dealer.
/ 3510 will not start #2
You were using FEL in too high of gear? Do you mean you rammed into something going too fast with fel and engine died? I saw a post recently, might have been an older mahindra even where a guy had a siezed hydraulic pump and that kept his engine frozen when he tried to start. If you hit something hard and it caused an immediate jump in the hyd pressure maybe it damaged the pump? Just a guess, I am not an expert by any means.
In my case if it is a warrantied item, since yours is so new I am guessing it is, the dealer will come out and pick up the tractor for free and check it out.
here is the thread I was thinking of:
http://www.tractorbynet.com/forums/showflat.php/Cat/0/Board/mahindra/Number/632702/page/0/view/collapsed/sb/5/o/all/fpart/1
/ 3510 will not start #3
Make sure you do the obvious first...
Check to make sure the pto is not engauged
Make sure you have the seat switch down
Make sure you press the clutch
If it does not start then you might have a bad ignition box which is behind the dash panel
We just replaced one on a 2810
/ 3510 will not start #4
I would guess that stalling the tractor and it not starting now are unrelated. Check the ground, It has been a problem on more than one 4110 (including mine). Remove the bolt the ground is on and scrape the paint off the tractor frame with a knife or straight blade screw driver, reinstall it and try again.
New/Unused Quick Attach Auger (A65583)
New/Unused Quick...
2022 EZ-GO ELITE...
set of 4 tractor trailer tires Roadforce (A63689)
set of 4 tractor...
New/Unused Landhonor Quick Attach Pallet Forks (A65583)
New/Unused...
2020 CATERPILLAR 239D3 SKID STEER (A65053)
2020 CATERPILLAR...
ROADTEC RX700 MILLING MACHINE (A62129)
ROADTEC RX700...
