3510 slipping out of gear
   / 3510 slipping out of gear #1
grunewald
St. Hedwig, Texas
Mahindra 3510
Probably need minor adjustment.
Probably just need a minor adjustment.
Probably just need a minor adjustment. Building a hill with left over dirt from digging out a tank, hill is fairly steep. Go up hill in 4 wheel drive, M range, 3th gear., no problem, but sometimes backing down hill the M range slips out of gear. Have not checked nor tried to adjust linkage yet, would like some pointers before I start tinkering with it.
   / 3510 slipping out of gear #2
You are not alone. Same thing happens to my 3510 going down steep hills frontwards or backwards. Scary at first but just a minor nuisance once you know of the possibility and keep your foot close to the brake. Still, it would be great to know the fix, especially if it is an easy one!
Rusty
   / 3510 slipping out of gear #3
I had a customer that had one doing it backing down the hill. I would have to look back on my paperwork to know the exact details, but it required splitting the tractor and replacing some forks and gears. Good luck with it.
   / 3510 slipping out of gear #4
Not the answer I was hoping for, but thanks anyway. Not urgent in the least, but if you do find those details or a cost on the fix (I am out of warranty), I'd be interested in hearing them.
Rusty
Not what I wanted to hear. Hoping just a linkage adjustment.
2011 Ford Crown Victoria Sedan (A51694)
2011 Ford Crown...
1999 Case 90XT Skidloader (RUNS) (A50774)
1999 Case 90XT...
2002 FREIGHTLINER FL70 DUMP TRUCK (A51406)
2002 FREIGHTLINER...
2022 FORD F-150 XL EXT CAB TRUCK (A51406)
2022 FORD F-150 XL...
New Holland 5 HP Hit And Miss Engine (RUNS) (A50774)
New Holland 5 HP...
(4) 10' High Pole Swinging Gates (A50515)
(4) 10' High Pole...
