3510 pto auto position
/ 3510 pto auto position #1
grunewald
St. Hedwig, Texas
Mahindra 3510
Happy with my new 3510, 2 months old, 150 hrs., really stay busy on it. But the pto has never worked in the auto position, works fine in manual. Any suggestions? Have not really taken any time to check myself, is under warranty, just not in a hurry to be without tractor for awhile at dealer. Also the directional signals do not work all the time, hazard lights do work all the time. Appreciate any so called quick fix.
/ 3510 pto auto position #2
Umm, I think the lift arms have to be down a certain distance to get the PTO to work in the AUTO mode. Since it works in the manual mode, I don't think it would be a bad solenoid or anything. Have you tried moving the lift arms up and down to see if that makes a difference? Got the red button pushed ??
/ 3510 pto auto position #3
My directional signals worked only once in a while on my fairly new 2810. The hazard flashers always worked. My horn didn't work at all. I took the "dashboard" cover off and unplugged the "combo" switch and checked the wiring and the switch itself and could find nothing wrong. I plugged it back together and everything worked! I guess it was just a bad connection in the plug. Now the directional signals and horn work consistently. Of course I really don't use them in my normal, around the property, use.
/ 3510 pto auto position #4
</font><font color="blue" class="small">( My directional signals worked only once in a while on my fairly new 2810. The hazard flashers always worked. My horn didn't work at all. I took the "dashboard" cover off and unplugged the "combo" switch and checked the wiring and the switch itself and could find nothing wrong. I plugged it back together and everything worked! I guess it was just a bad connection in the plug. Now the directional signals and horn work consistently. Of course I really don't use them in my normal, around the property, use. )</font>
Sounds like it may not have been plugged in completely during assembly and wasn't making good contact.
2020 Takeuchi TL8R2 Track Loader with 72in Tooth Bucket (A63689)
2020 Takeuchi...
Lincoln SAE-400 Shield-Arc DC Arc Welder - Inoperable (A63689)
Lincoln SAE-400...
2013 John Deere 825I (A64127)
2013 John Deere...
Case IH 315 Magnum (A62177)
Case IH 315 Magnum...
2005 SBX-5 Box Blade Tractor Attachment (A61572)
2005 SBX-5 Box...
2021 UTILITY VS2DX 53x102 T/A DRY VAN TRAILER (A59914)
2021 UTILITY VS2DX...
