3510 Hydro issue after fluid and filter change.
   / 3510 Hydro issue after fluid and filter change. #1
M. Lowes
I bought my branson 3510 tractor from an individual. I have put 60 hours on it. It now has 372 hours. I thought it would be wise to change the fluid.
I purchased a wix hydro filter 51202. Bought 10 gallons of ultra premium UTF Has listings for Case, New Holland, Cat, Kubota, etc.
After the change I used it and everything felt normal.
I have only used the tractor to blade the roads of snow.
When I start the tractor the pump sound loud. No power steering, loader operates slow, 3 pt slow. It's like there is air in the system.
Takes awhile running and it's normal.
Next snow hits and it's back to same slow hydro's
I have done this twice.
Did I purchase the wrong hydro filter?
It' is cold, but I have bladed snow before with no issues.
   / 3510 Hydro issue after fluid and filter change. #2
If this is like my 2400H the filter for the hydraulics is an inlet filter or suction filter. If you purchased a filter with a finer filtration or higher pressure drop Vs flow it will cause the pump to cavitate.
   / 3510 Hydro issue after fluid and filter change. #3
There are other posts with problems with non OEM hydraulic filters. You might try a search.
Was the old filter a Branson?
Did you clean the screen?
The old filter was a Branson brand. I brought the tractor into the shop and put the old filter on. It instantly worked. Surly other brand filters can cross reference. I have used Wix filter on my applications from the big high lifts to the lawn mower.
   / 3510 Hydro issue after fluid and filter change. #5
Do a forum search. I seem to recall some past posts with filters that cross/work.
That being said - Is a dealer close by? The factory filters are pretty reasonable, and even if more $, you only change it every 200-300 hours...
My .02
   / 3510 Hydro issue after fluid and filter change. #6
m.Lowes,
Since I believe this is a pump inlet filter a minor change in micron rating or flow capabilities can have a drastic effect on the pump performance especially in colder weather. Yes Wix makes a quality product but if it is not a functional interchange you will have the problems you are seeing.
If this was a return line filter I doubt you would have seen any difference in the operation of your tractor.
I have not found any filter manufacturers than show a cross over for Branson hydraulic filters.
Hyster H225E (A47384)
UNUSED CFG Industrial MY50R Mini Excavator (A47384)
UNUSED CFG...
2008 BMW 528i Sedan (A50324)
2008 BMW 528i...
2015 Ford Explorer AWD SUV (A50324)
2015 Ford Explorer...
71059 (A49346)
71059 (A49346)
12 foot two person Terry aluminum John boat (A50324)
12 foot two person...
