3510 Hydralic Hookup
/ 3510 Hydralic Hookup #1
Stimw
Elite Member
N. E. Florida
I got a good deal on a Jinma Backhoe and I plan to hook it up on my 3510 Branson. Mounting is not a problem because I own a Welding/Fab shop and I can build a sub frame to fit.
What I need to know is if the rear hydralic hook ups come as a kit to add on to the tractor? Price?
Looking under the right fender I can see 2 ports connected with a bypass fitting, is this where it would connect? Tractor owners manual shows a maze of lines connecting at this area but no kit for hook up.
Also are hydralic fittings standard or is there US and metric?
Hoe came with a pump but it is designed for the Jinma. I could adapt it to PTO shaft but it is designed to turn CC by the arrow on pump.
/ 3510 Hydralic Hookup #2
The Jinma pump will spin at the wrong rpm, it is sdesighned to run off the shaft that drives the pto shaft, You might also want to do alittle bit of modifications to the LW backhoe prior to usage, We had several that self destructed, The LW6 was better than the LW 7,The biggest issue was the cylinder rod would shear off where it pins to the end, "V" out the end and weld a nice bead was the fix for that but in your sandy soil it may not be an issue. Best bet for the hydraulics is to get the proper backhoe hydraulic kit.You can PM me for a quote-Good luck
Bainbridge,Georgia (A65640)
Bainbridge,Georgia...
2025 CATERPILLAR 255 SKID STEER (A65056)
2025 CATERPILLAR...
BOOM FOR HYDROVAC TRUCK (A68842)
BOOM FOR HYDROVAC...
2026 BIG TEX DUMP TRAILER (A67714)
2026 BIG TEX DUMP...
2016 Ford Expedition SUV (A66738)
2016 Ford...
2010 Freightliner M2 106 Pac-Mac KBF 20H Forestry Grapple Truck (A66736)
2010 Freightliner...
