3510 filters
/ 3510 filters #1
mike45tx
South Texas
Mahindra 3510/FEL
Has anyone crossed over oil and hyd. filters to aftermarket filters on a 3510?
Thanks
Mike
/ 3510 filters #2
Not yet. There was a thread on the oil filter xover to a WIX (I think)
/ 3510 filters #3
engine oil.... Baldwin b202
Napa 1724
/ 3510 filters #4
</font><font color="blue" class="small">( engine oil.... Baldwin b202
Napa 1724 )</font>
Wallace,
Are you sure its not a Napa 1324.
The Baldwin b202 crosses over to a Napa 1324.
I run a Napa 1324 on my 35 HP DaeDong engine..
/ 3510 filters #5
Yes it is, my mistake. /forums/images/graemlins/crazy.gif can't read my own righting.
Thank you for catching that. I don't want to mislead anyone.
/ 3510 filters #6
Wrote down some Nunbers from "old" posts, have not checked them out since my dealer charges only $9.95 for the oil filter on my 4110. Plus I was worried that by using a non-Mahindra filter it might void my warranty? Just being Cautious?
Napa 1182
Napa gold 1324
Motorcraft FL-786
Wix 51182
I have not tried any of the above - this is info from past threads?
I have no first hand knowledge that they work??????????
Ron
/ 3510 filters #7
Ron,
I couldn't find the Motorcraft FL-786 in my book, so I don't know if they will work.
But I do know the Napa 1182 (same filter as the Wix 51182) and the Napa 1324 will work on the DaeDong 35 and 40 HP engines.
The direct crossover for my DK 35 is the Napa 1182/Wix 51182, but they are slightly larger in diameter and lenght than the stock DaDong filter and I'm pressed for space so I run the Alternate (Napa 1324) which has similar specs but is a bit shorter than the 1182.
I hope I'm making any sense /forums/images/graemlins/tongue.gif
/ 3510 filters #8
Vince
Thanks for the info, since you do have first hand knowledge
I will consider the napa filter for my next oil change. These filters will also work for Mike45tx and his 3510
Ron
(12) John Deere 1.5bu. seed boxes for JD 7200 planter, Taylor Ridge, IL (A65640)
(12) John Deere...
Freightliner Columbia (A63689)
Freightliner...
2019 FORD F-250 SUPER DUTY (A65643)
2019 FORD F-250...
Landhonor Livestock Chute (A66408)
Landhonor...
2015 IC Corporation PB105 School Bus (A61573)
2015 IC...
2yd. Self Dumping Hopper (A65640)
2yd. Self Dumping...
