3500 tires
   / 3500 tires #1
zombie
Boring, OR
Ford 3500 industrial
Hey guys, i've been lookin around for parts for my tractor and todays search has been for tires. My rear tires are 14.9-24, pretty simple, not bad to find. But I don't know what size should be on the front of it. It has auto tires on it right now. I think they are 245 75 16 (just from memory). What would normally be on the front of this and what style? it is an industrial 3500 with a fel and box on the back. Thanks!
   / 3500 tires #2
Tractor data.com list a 3600 as having 16.9 x 24 on the rear and 6.00 x 16 on the front. There is no 3500 listed.
   / 3500 tires #3
If it has a loader, go for multi rib fronts, not tried ribs, more Ply=better.
6 or 6.5-16 works. I have 6-16 on a similar tractor
   / 3500 tires #4
The 3500 Operator's Manual lists a range from 6.00-16 (4-ply) to 9.00-16 (10-ply l1). Load range varies from 1130 lbs to 2940 lbs for these. The 3500 max. vehicle weight (empty buckets) is 10,200 lbs; the max. static front axle weight with filled buckets is 7000 lbs. If you are working the tractor with a backhoe and a filled loader, you would want tires at the higher ratings. My own 3500 has 11L-16SL, which are specified as a backhoe application. They are Denman Super Backhoe II, 10-ply rating, 3762 lbs at 10 mph at 52 psi cold.
   / 3500 tires
I know it's long overdue, but I wanted to thank everyone that contributed to this thread. I got so busy with other things that I forgot about it. I have to do some tire shopping for one of the rear tires tomorrow. Tube is leaking and sidewall is coming apart. Fronts are going to have to wait.
JOHN DEERE 5115M TRACTOR (A51243)
JOHN DEERE 5115M...
1978 Taylor TY-250M Forklift (A53117)
1978 Taylor...
1990 UNKNOWN 16 T/A TRASH TRAILER (A53843)
1990 UNKNOWN 16...
2006 Nissan Titan Crew Cab Pickup Truck (A53422)
2006 Nissan Titan...
40'' root grapple (A53421)
40'' root grapple...
1274 (A50490)
1274 (A50490)
