LBrown59
Super Star Member
- Joined
- Oct 27, 2004
- Messages
- 16,904
- Tractor
- 2003 Kubota BX1500/2004 Kubota Bx23/2005 Kubota BX1500
Suits Me.sandman2234 said:I think both of us should be man enough to drop it. David from jax
klh92 said:1*I tried both the CC and the JDs....in the end, I chose the JD x340, got it for $4100.
2* The CC does look like it is a bit bulkier and heavier and I am sure I would have been more than satisfied with it.
3*The only issue on the JD so far is using it on hills.
4*Wish it had some better traction control if you have to rock it to get traction, it shuts off.
5*I'm checking on some wheel weights or something to help out.
6*Yep when you get into that kind of money for a garden tractor you're ahead to go with a good new or used small sub compact tractor.
I can buy a used low hour Kubota BX1500 S-Cut with a 48'' mower for $6000.
It comes standard with 4x4 Power steering Roll BAR Differential lock and rear PTO and 3 point hitch, which solves all issues of traction on hills and no extra weight is needed.
Another advantage of the BX1500 is it's a diesel which means less fuel consumption than the gas hog V twin cylinder gasoline engines on the garden tractors.
It also means I can justify home fuel delivery at a lower price per gallon; and no more time wasting trips lugging back breaking 5 gallon cans to the service station throwing money away on the more expensive fuel.
I'm beginning to realize I made a mistake in buying the CC2554 not because it's not a great machine because it is.
The problem is It wasn't the right choice of equipment to meet my wants / needs.
If I had it to do over again I would have went with the BX1500 S-Cut instead of the CC 2554.
__________________
klh92 said:I tried both the CC and the JDs....in the end, I chose the JD x340 The only issue on the JD so far is using it on hills....one, wish it had soem better traction control and two if you have to rock it to get traction, it shuts off. I'm checking on some wheel weights or something to help out. quote]
Why didn't you notice the traction defferences between the JD and the CC when you tried them out on your hills?
klh92 said:Well, I seem to have caused a stir. I do thank you all for your comments. I checked this thread quite often after my original post and didn't see much action...seems it all came in the recent days.
I tried both the CC and the JDs....in the end, I chose the JD x340, got it for $4100. I've already mowed once with it and absolutely love it. The foot control and turning of the JD won me over for what I needed. The CC does look like it is a bit bulkier and heavier and I am sure I would have been more than satisfied with it. The only issue on the JD so far is using it on hills....one, wish it had soem better traction control and two if you have to rock it to get traction, it shuts off. I'm checking on some wheel weights or something to help out. I wish I would have been able to go up a series to the 500 to get the differential, but as we all know money was the issue. I'll try to get some pics and post back after more usage. Thanks again for all the feedback...hope to run into some of you fellows at a lawn near you soon.
Patches said:Scott VT: couple nice A's you got thereWhat vintage are they
