3500 3ph
   / 3500 3ph #1
bksanti
Chino valley az
1968 ford 3500
Just bought a ford 3500 industrial with 3ph
The lift drops after i shut the tractor off and won't holed
And jerks when up. Thanks
   / 3500 3ph #2
On a lot of older tractors you could adjust the draft of the 3ph. You may have a lever or knob around the seat/floor pan area. Also go on line to NH. I've used them several times.
   / 3500 3ph #3
The lift piston oring is probably worn out and/or (more severe) the cylinder is scored. The jerking or hiccuping is caused by the hitch trying to maintain the position after it leaks down slightly.
The oring is not really expensive or a difficult repair. The cylinder, on the other hand, is either not replaced or is $2000-2800 range. It can be sleeved by a capable machine shop.
2016 FORD F250 XL SUPER DUTY EXTENDED CAB TRUCK (A51247)
2016 FORD F250 XL...
2018 Case TR270 High Flow 2-Speed Compact Track Loader Skid Steer (A51691)
2018 Case TR270...
UNUSED SWICT 72" QUICK ATTACH BUCKET (A51248)
UNUSED SWICT 72"...
2025 New/Unused Wolverine Pallet Fork Extensions (A51573)
2025 New/Unused...
UNUSED JCT 72" HD VIBRATORY ROLLER (A51248)
UNUSED JCT 72" HD...
UNUSED HURRICANE F10 10' WROUGHT IRON SITE FENCE (A51248)
UNUSED HURRICANE...
