3500 3ph
   / 3500 3ph #1
bksanti
Chino valley az
1968 ford 3500
Just bought a ford 3500 industrial with 3ph
The lift drops after i shut the tractor off and won't holed
And jerks when up. Thanks
   / 3500 3ph #2
On a lot of older tractors you could adjust the draft of the 3ph. You may have a lever or knob around the seat/floor pan area. Also go on line to NH. I've used them several times.
   / 3500 3ph #3
The lift piston oring is probably worn out and/or (more severe) the cylinder is scored. The jerking or hiccuping is caused by the hitch trying to maintain the position after it leaks down slightly.
The oring is not really expensive or a difficult repair. The cylinder, on the other hand, is either not replaced or is $2000-2800 range. It can be sleeved by a capable machine shop.
2007 Ford E350 (A55973)
2007 Ford E350...
2386 (A58376)
2386 (A58376)
Schulte SBW800 Rock Windrower (A56438)
Schulte SBW800...
John Deere 5105M (A53317)
John Deere 5105M...
2013 FREIGHTLINER CASCADIA (A55745)
2013 FREIGHTLINER...
FORD F550 SUPER DUTY SERVICE TRUCK (A52707)
FORD F550 SUPER...
