3500 3ph
   / 3500 3ph #1
bksanti
Chino valley az
1968 ford 3500
Just bought a ford 3500 industrial with 3ph
The lift drops after i shut the tractor off and won't holed
And jerks when up. Thanks
   / 3500 3ph #2
On a lot of older tractors you could adjust the draft of the 3ph. You may have a lever or knob around the seat/floor pan area. Also go on line to NH. I've used them several times.
   / 3500 3ph #3
The lift piston oring is probably worn out and/or (more severe) the cylinder is scored. The jerking or hiccuping is caused by the hitch trying to maintain the position after it leaks down slightly.
The oring is not really expensive or a difficult repair. The cylinder, on the other hand, is either not replaced or is $2000-2800 range. It can be sleeved by a capable machine shop.
MMS MS36C Skid Steer (A57149)
MMS MS36C Skid...
(NEW) POLY HI-CYCLE TANK (A52708)
(NEW) POLY...
Cummins DGCB 60 kW Standby Diesel Generator (A56857)
Cummins DGCB 60 kW...
2135 (A58376)
2135 (A58376)
2018 Ford F-150 Pickup Truck 4x4 (A56858)
2018 Ford F-150...
2019 PETERBUILT 579  DAYCAB (A58214)
2019 PETERBUILT...
