Oil & Fuel 3400 fuel leak
   / 3400 fuel leak #1
bigballer
Platinum Member
PNW - North Central bWashington - The Evergreen St
2006 Kubota L3400
tonight after i changed out the hydraulic inlet hose i ran the tractor for a few minutes and turned some manure, when i put it away i noticed fuel dripping at the bottom of the pump assembly. there are 2 hoses there one coming in from the filter bowl and another going out to the injector pump. i'm thinking one of them is leaking but when i cleaned it up and ran it some more i didn't see any fresh fuel surfacing around the connections. odd that it was dripping noticably then just stopped. i'll keep an eye on it..
   / 3400 fuel leak #2
Check the black plastic housing the hoses and bowl are connected to for cracks.
   / 3400 fuel leak #3
I had a l3400 at one time and I think I had something like this happen. But it was with when I changed the fuel filter the housing is not for a better word sort of finicky. Has to be put put together sort of delicately?? Other than that it was a Great tractor ended up trading it on a L4400:D
   / 3400 fuel leak #4
Sounds like that dang Murphy guy. Fix one thing and another fails.
Hope it was a fluke.
   / 3400 fuel leak
i figured it out, it's the line between the fuel pump and the injection pump. i tried to tighten the clip on the connection but didn't help much, i guess the line is hardend or cracked. i'll be ordering a replacement line and will probably just swap out all the fuel lines while i'm at it.
in case curious, i've attached a picture of the part - it's 120/130
2013 FORD F-150 XL SINGLE CAB TRUCK (A51406)
2013 FORD F-150 XL...
2014 Chevrolet Tahoe SUV (A51694)
2014 Chevrolet...
2020 CATERPILLAR D6K2 LGP CRAWLER DOZER (A51246)
2020 CATERPILLAR...
Yale 50LX Cushion Tire Forklift (A49461)
Yale 50LX Cushion...
2019 Allmand Night-Lite V-Series S/A Towable Light Tower (A52377)
2019 Allmand...
Blue Concrete Test Shed (A52377)
Blue Concrete Test...
