334 Latching X-change Bushing Replacement
/ 334 Latching X-change Bushing Replacement #1
JackinVT
Jay
Kubota
Hello,
I recently broke a pin (6806971) in my latching X-change, seems hard to believe given it's size. I believe the lock pin fell out and the pin worked it's way out then broke off. It appears that on it's way out the pin took the bushing with it, as it is half way out and cracked around the perimeter. I have new parts including the "Press Bushing Fit, 6802889". My question is, is removing and replacing the bushings something I can do on my own with some improvising or do I need to take it to a machine shop? I do not own a press, but I do own a vise, and usually get things like this done on my own. Any suggestions on approach, heating x-change, cooling bushing, large bolt/nut with sockets for spacers,....etc. would be greatly appreciated.
Thanks!
Jack
Well it is done. Bolt, nut, washers, and sockets did the trick.
Sorry, I couldn't wait for a response.
2012 Audi Q5 3.2 Quattro Triptronic (A62679)
2012 Audi Q5 3.2...
1997 TSE UTILITY WIRE REEL TENSIONER (A62613)
1997 TSE UTILITY...
Stertil Koni 18000lbs 4-Post Auto Lift (A61572)
Stertil Koni...
2004 CATERPILLAR 416D BACKHOE (A60429)
2004 CATERPILLAR...
2017 BX2680 Sub Compact Utility Tractor (A63688)
2017 BX2680 Sub...
2013 Volvo BL70B 4x4 Extendahoe Loader Backhoe (A61572)
2013 Volvo BL70B...
