3320
/ 3320 #1
DHUR
southwest ohio
jd4005 & X750
can someone who has a 3320 wth cab thell me me how many wheel weight I can put on each side 2 or 3. thanks for your help. I am going to buy a used 2008 with 328 hours on it and the dealer said he would put on what I wanted. I am trading In my 4005 whitch has 3 on each side . I have copd and I need the cab. they will be 110 lbs each.
/ 3320 #2
The 3x20 series w/cab is taller than it is wide, and therefore is quite prone to being "tippy". I had mine up on three (unballasted) wheels more times than I care to count. First I reversed all four rims, no help. And I refused to pay the rip-off price the dealer wanted for wheel weights. So I installed a pair of 4" machined aluminum spacers on the rear hubs, then added nearly half a ton of RimGuard to all four tires. Total cost $550, tipping issue completely solved.
So regarding wheel weights on the 3x20 series, the more the merrier (and safer too). That said, I'm pretty sure $550 isn't enough to buy even 4 (new) 110# wheel weights.
//greg//
/ 3320 #3
Take a look at THIS thread.
It will have all the info you need. I think the weights for the 3x20's are 55 lbs
BG PF5 HIGH OUTPUT POWER FLUSH AND FLUID EXCHANGE SYSTEM (A65643)
BG PF5 HIGH OUTPUT...
2003 Coleman Pop Up Camper (A62613)
2003 Coleman Pop...
John Deere Starfire 6000 (A64126)
John Deere...
84in 3in1 Combo Bucket (A65579)
84in 3in1 Combo...
BUCK STOVE FIREPLACE INSERT (A64276)
BUCK STOVE...
John Deere 1025R (A62177)
John Deere 1025R...
