3320 Hydraulic pressure seems low
   / 3320 Hydraulic pressure seems low #1
offroadr
Central IL
JD 3320
I have a 3320 with about 200hrs on it and I am noticing that I no longer have they hydro speed or FEL power I used to have. For example when I start moving in 'B' range it will take off with a decent acceleration and speed but then slows down. RPM doesn't change it (once you hit an RPM that works the hydro). FEL has full range but not the lifting power it used to. Engine runs great and hyd level is perfect. I have changed the fluid and filter but its been a while ago (couple years as I do not put many hours on the tractor)
Any thoughts?
   / 3320 Hydraulic pressure seems low #2
Suction filter collapsing :confused3: . . . But that doesnt explain FEL pressure loss. :confused2:
   / 3320 Hydraulic pressure seems low #3
Get yourself an inexpensive pressure gauge and attach it to a hose with quick connect to check the pressure at the loader SCV. That will determine if you have a pressure problem. Do you have the service manual?
Guard Rail Joints (A51692)
Guard Rail Joints...
HURRICANE 7' X 12' CONTAINER (A51248)
HURRICANE 7' X 12'...
WOODS TBW15.40 LOT IDENTIFIER 228 (A53084)
WOODS TBW15.40 LOT...
(INOP) CATERPILLAR CB-434 SMOOTH DBL DRUM ROLLER (A51247)
(INOP) CATERPILLAR...
2018 Mazda CX-5 SUV (A51694)
2018 Mazda CX-5...
JOHN DEERE 608C LOT IDENTIFIER 19 (A53084)
JOHN DEERE 608C...
