Mowing 3320 6'or5' brush hog
   / 3320 6'or5' brush hog #1
joed3320
Hinesburg,VT
Johndeere
I want to move up from my DR field and brush to a tractor mount, can my 3302 handle thick seeding with a 6' along with small saplings?
   / 3320 6'or5' brush hog #3
I would not recommend a 6 foot bushhog for the 3320. My mom's 5 foot King Kutter can bog fairly easily on her cab/air 3320 even at 2600 rpm, blades sharp etc, while my 3038e handles a 6 foot RC 2072 with ease even at 2100 rpm. I wonder if the load demands of the cab/air setup saps more hp than JD specs let on. Based on how dramatic the difference is, if my 3038e really produces 30 PTO hp, then I can't believe my mom is getting 25 out of hers. It seems more like 20 - 22. Perhaps if you have an OS tractor, you would fare better but I would surely recommend borrowing someone's 6 footer to try before you bought one.
   / 3320 6'or5' brush hog #4
the HP is probably fine, but I'd focus on weight.
1) do you have hills
2) will you get front weights
I purchase a Heavy Duty Woods 72" for my 4720 cab and the front wheels came off the ground too easy. I had to send it back for a Standard Duty 72" and buy front weights. I have a lot of hills too.
A co- worker offered up his woods 6' to try great suggestion.The weight is a issue I have no extra weight in the front . I will have to address this, steep hills to mow.:confused2:
   / 3320 6'or5' brush hog #6
I would recommend the 5'. I run a JD MX6 on a JD 5303 and had been running it behind a JD 5105. You can tell it's there when in deep bahia grass. I think the 5' would be better suited. You can probably run it, but may have to go slower or cut smaller swaths.
   / 3320 6'or5' brush hog #7
I would recommend the 5'. I had an OS 3520 with a 6 footer, and it would bog down in 2' high thick grass/weeds.
   / 3320 6'or5' brush hog #8
I think if you check the specifications for the 3320 you will find the 6' is rated as being too big. Safety is a big issue and the extra weight might well be a problem.
I have a 3520 and a 5' brush mower. If I were in short weeds it might handle a 6', but I would be doubtful
Good luck and stay safe.
   / 3320 6'or5' brush hog #9
Really, the issue is not going to be ballasting a 6 foot bushhog on the 3320, but power. The 3320 has a heavier front end than my 3038e, but with enough 70# suitcase weights (8 of them plus the weight of the front hood guard) I have had no trouble ballasting a 6 foot hog, and my land is very hilly. PTO power is the issue.
   / 3320 6'or5' brush hog #10
MSMUD - Agree that ballasting is not the big issue. You are correct and that is what I did a poor job of saying. The 3320 doesn't have enough horsepower.
Thanks for helping clarify.
2016 Big Tex 24ft. T/A Flatbed Trailer (A50323)
2016 Big Tex 24ft...
NEW Ripper Shank (A53002)
NEW Ripper Shank...
2006 KENWORTH T800 TANDEM SLEEPER TRUCK (A52141)
2006 KENWORTH T800...
2008 Ford Ranger Pickup Truck (A51692)
2008 Ford Ranger...
2018 MDB T5E MDB DISC MOWER (A51406)
2018 MDB T5E MDB...
2002 Ford F-350 Crew Cab Pickup Truck (A50323)
2002 Ford F-350...
