325 Pulley Chirping
/ 325 Pulley Chirping #1
topsaiilbye
Ottawa, Ontario, Canada
John Deere 325
I have a 325 with 600 hrs.
cant seen to locate it . Short of replacing all 3 pulleys any thoughts on how to locate the guilty one
/ 325 Pulley Chirping #2
Pop the belt off, and spin each spindle (assume that is what is meant by "pulley") by hand to listen for grinding, as well as rock (shake) for any sloppiness in the bearings. If a bad bearing, likely will be able to hear it grind.
Also, after running for awhile, shut off and feel each spindle for excessive heat.
replaced all 3 pulleys. it turned out it was the small pulley on the belt tensioner assy.
JOHN DEERE 8360R TRACTOR (A64278)
JOHN DEERE 8360R...
2019 GMC Canyon SLE 4X4 (A62679)
2019 GMC Canyon...
Deer Staute (A64557)
2008 JLG 3246ES 32ft Scissor Lift (A64553)
2008 JLG 3246ES...
2016 Toyota Tundra Ext. Cab Pickup Truck (A64556)
2016 Toyota Tundra...
2002 Mitsubishi Lancer Sedan (A64557)
2002 Mitsubishi...
