3200 attachments
/ 3200 attachments #1
jmt1271
Platinum Member
MO
Kubota L2501
i have a cub 3200 GT and would like an attachment for prepping my yard to be sewed with grass. where should i look and what aattachments are the best. i dont really need a tiller do i? help.
/ 3200 attachments #2
Is your yard really rough...like will it need to be filled with some dirt, or is it pretty smooth already, just needing reseeding? If it is already smoothed out...you should be able to just use a broadcast seeder. Put down what you think you need for seed then use your tractor with a small drag and drag it in, the water it twice daily. Should be enough. Note...if there are alot of weeds...this might be the time to address that situation before reseeding.
There are several companies who make a small drag which can be pulled behind a lawn tractor. I just use a single drag section which was left over from some dismantled farm equipment.
2014 ALLMAND MAXI-HEAT PORTABLE HEATER / GENERATOR UNIT (A67714)
2014 ALLMAND...
2020 GMC AT4 CREW CAB TRUCK (A64280)
2020 GMC AT4 CREW...
2023 JCB S3246E ELECTIC SCISSOR LIFT (A63276)
2023 JCB S3246E...
2005 Bobcat B950 Hydraulic Breaker Skid Steer Attachment (A66734)
2005 Bobcat B950...
T/A CO2 Tanker Trailer (A64194)
T/A CO2 Tanker...
2014 FORD F-150 (A67714)
2014 FORD F-150...
