3184 Fuel Problem
/ 3184 Fuel Problem #1
sadieseal
Providence Forge, Va
I have a 3184 I think its about 10 years old and it has been great all of those years. Its starts but when I release the key it shut down, as long as I hold the key on it runs fine. Thier must be a switch that is shutting down the fuel but I cant find one. I hoping that someone can help me track this down.
Thanks,
Steve
/ 3184 Fuel Problem #2
Maybe you have a bad ignition switch. Are you saying that holding the switch in the cranking position allows it to run and releasing it to the normal ON position it stops? There is a separate contact in the switch to provide voltage to the coil while cranking and when you release the switch it uses a different contact.
Bob B.
2022 EZ-GO ELITE...
1994 CHEVROLET GMT-400 EXTENDED CAB TRUCK (A65054)
1994 CHEVROLET...
2019 International LT625 Sleeper 48 (A62613)
2019 International...
2014 International WorkStar 7300 4x4 Altec A55F 55ft. Material Handling Bucket Truck (A60460)
2014 International...
2019 CHEVROLET SILVERADO CREW CAB TRUCK (A59823)
2019 CHEVROLET...
2007 Mack CV713 Granite T/A Pole Truck (A62679)
2007 Mack CV713...
