3184 Fuel Problem
/ 3184 Fuel Problem #1
sadieseal
Providence Forge, Va
I have a 3184 I think its about 10 years old and it has been great all of those years. Its starts but when I release the key it shut down, as long as I hold the key on it runs fine. Thier must be a switch that is shutting down the fuel but I cant find one. I hoping that someone can help me track this down.
Thanks,
Steve
/ 3184 Fuel Problem #2
Maybe you have a bad ignition switch. Are you saying that holding the switch in the cranking position allows it to run and releasing it to the normal ON position it stops? There is a separate contact in the switch to provide voltage to the coil while cranking and when you release the switch it uses a different contact.
Bob B.
2021 Mercedes-Benz Sprinter 4500 Modified Food Catering Van (A61573)
2021 Mercedes-Benz...
Oxy-acetylene Torch and Regulator Rig (A63689)
Oxy-acetylene...
2021 Felling FT-45-2LP 29ft. 26 Ton Tag Trailer (A64194)
2021 Felling...
NEW Rachet Tie Downs and Flatpack Tool Box (A62679)
NEW Rachet Tie...
1999 Fruehauf (A64127)
2018 22ft. Tycorp Vector Belt VB-16H (A60352)
2018 22ft. Tycorp...
