3184 Fuel Problem
/ 3184 Fuel Problem #1
sadieseal
Providence Forge, Va
I have a 3184 I think its about 10 years old and it has been great all of those years. Its starts but when I release the key it shut down, as long as I hold the key on it runs fine. Thier must be a switch that is shutting down the fuel but I cant find one. I hoping that someone can help me track this down.
Thanks,
Steve
/ 3184 Fuel Problem #2
Maybe you have a bad ignition switch. Are you saying that holding the switch in the cranking position allows it to run and releasing it to the normal ON position it stops? There is a separate contact in the switch to provide voltage to the coil while cranking and when you release the switch it uses a different contact.
Bob B.
2019 VOLVO L90H WHEEL LOADER (A65053)
2019 VOLVO L90H...
GYRO-TRAC (A65053)
GYRO-TRAC (A65053)
2011 BRENNER TANK TRAILER (A65643)
2011 BRENNER TANK...
John Deere X380 Riding Lawn Mower (A66285)
John Deere X380...
Gehl Mix-All 95 Grinder Mixer (A64047)
Gehl Mix-All 95...
2008 SUBARU LEGACY 4 DOOR SEDAN (A64280)
2008 SUBARU LEGACY...
