318 or 420 owners I need help with a picture
   / 318 or 420 owners I need help with a picture #1
OutbackL130
chickamauga
L130, 420
I have a john deere 420 and when I bought it the rear body was not attached to the frame. It would help to see a picture of the spacers used between the frame and the front of the rear body where it attaches.
   / 318 or 420 owners I need help with a picture #2
My Son's got a 420. I was there one day when he had it apart. I think it used those rubber spacers that have a stud coming out of the top and bottom??? I think it was the same at the rear of the fender assembly. I had a 322 and it was built that way. I couldn't tell you a thickness measurement though. I'm pretty sure you are gonna want something like that or the vibration is gonna be really bad!!!
I made metal spacers for it and you are right the vibration was just too much. Now I found and ordered factory rubber isolators from jd.
   / 318 or 420 owners I need help with a picture #4
Watch those rubber spacers! They break easily. Install them and when they break at the glue point fabricate your own using a rubber isolator and a through bolt. No more problems after that!
   / 318 or 420 owners I need help with a picture #5
Yep, but unless you use an isolator on both sides of the fender and both sides of the frame, you still will have bolt vibration.
   / 318 or 420 owners I need help with a picture #6
Try it. You'll be surprised.
   / 318 or 420 owners I need help with a picture #7
Tried it several years ago on my old 322. Just used a rubber shock bushing between the fender assembly and the frame. That left the bolt head with washer and nut with washer against metal. Transmitted every bit of the vibration into the fender assembly and then into the seat. Would actually make the bottoms of my feet tingle like they were going to sleep after a couple hours of mowing. Switched to longer bolts with rubber washers added on top of fender and under frame and minimized the problem. But it wasn't as good as the isolators.
   / 318 or 420 owners I need help with a picture #8
I'm building a 1990 420 from scratch, where are these parts in the diagram?
24A and 24B? The grommets?
   / 318 or 420 owners I need help with a picture #9
Yep.....
   / 318 or 420 owners I need help with a picture #10
<img src="http://www.tractorbynet.com/forums/attachment.php?attachmentid=353588"/>
Either one. The longer is used if you install rear hydraulic lines as it raises the pan for clearance.
2017 Ford Fiesta SE Sedan (A51694)
2017 Ford Fiesta...
2018 Suzuki KingQuad 750 AXi 4x4 ATV (A51694)
2018 Suzuki...
2013 Ford F-550 Passenger Bus (A51692)
2013 Ford F-550...
UNUSED ECHO CS-4010 CHAINSAW (A51247)
UNUSED ECHO...
(APPROX 24) 2" X 3" X 39" TUBING (A51247)
(APPROX 24) 2" X...
2022 JOHN DEERE 6120M LOT NUMBER 191 (A53084)
2022 JOHN DEERE...
