318 john deere
/ 318 john deere #1
goatfarmhand
ashland city tennessee
john deere 318
just rebuilt a b 48 onan engine in the john deere but it wont run at all unless choke is closed off. ive tried replace filters lines surge pump everything but nothing seems to work. im going to recheck valve clearance any other ideas
/ 318 john deere #2
sounds like you have a plugged jet or the wrong jetting in the carb. did you rebuild the carb and replace the jets including pilot jet(used at idle)?
/ 318 john deere #3
Check to make sure your fuel pump is pumping. Check the crankcase vacuum to make sure your pulling enough vacuum to run the pump.
2017 Hyundai 53' Dry Van Trailer (A62613)
2017 Hyundai 53'...
2020 Takeuchi TL8R2 Track Loader with 72in Tooth Bucket (A63689)
2020 Takeuchi...
CATERPILLAR D6N LGP HI-TRACK CRAWLER DOZER (A65053)
CATERPILLAR D6N...
2019 RAM 5500 4X4 S/A ROLLBACK TRUCK (A59914)
2019 RAM 5500 4X4...
New/Unused Landhonor Tree/Post Puller (A65583)
New/Unused...
2020 Club Car Carryall 700 Gas Utility Cart (A61567)
2020 Club Car...
