317 Onan p218
/ 317 Onan p218 #1
317140
Bronze Member
North Carolina
John Deere 3520
I have a 317 with an onan p218 engine. the engine has locked up and will not turn over. I am getting ready to take it out of the tractor. I talked to a mechanic yesterday and he said some of these engines locked up because of a broken tang not lubing the bottom end. He also said he had sometimes freed these engines up by turning them backwards. He said on some of them there was an inspection plate that you could remove to check the damage. He said you could clean up the rod and crank and sometimes get it running again. This engine was a replacement for a kohler. I used an onan because I thought it would be a better engine. I was wondering if anyone had heard of this or had tried it. This engine has less 800hrs on it and I am just exploring options before I remove it and tear it completely down.
/ 317 Onan p218 #2
I have not heard of this but I do know some of the Onan engines had problems with lubing the cam bearings. When these bearings wore out it could cause the the cam gears to break. All of these I have seen never caused the engine to seize though.
/ 317 Onan p218 #3
No part of this engine is lubricated by a splash system,if that is what this so called "mechanic" is referring to by a broken tang.
The P218 is entirely lubricated by a pressurized oiling system.:)
Greg
/ 317 Onan p218
Thanks for the info. I hope to get into troubleshooting it this week. I have been too busy lately to give it any attention. Thats why I wont let him borrow my 3520.
/ 317 Onan p218 #5
the series one Kohler in the 317 was prone to engine failure, particularly if used on hills. The splash lube system was ineffective. They were replaced by a series II engine, which was fine. The 317 and 318 are almost identical. JD changed the number to recover from the damage the series I caused.
/ 317 Onan p218 #6
Glad to see someone has already pointed out the mechanics lack of knowledge about the oil system.
What you might do is pull the front shroud cover off and take a look at the starter. My 318 would from time to time get the starter and flywheel gears jamed. removing the starter to free things up and then reinstalled and all was back to normal for quite some time.
Might be possible to see if starer is jamed without pulling the shroud cover but pulling the cover sure offers a better view.
/ 317 Onan p218
My engine is an onan p218g replacement engine. I finally got it torn down. It had spun the crank bearing behind the electric clutch. It also broke a connecting rod and broke the skirt on the piston. I don't see any obvious damage to the cylinder wall. I was wondering if anyone has rebuilt one side and what kind of luck have they had. I am also looking for a good source for used parts and new gaskets. Thanks for any help
/ 317 Onan p218 #9
I haven't touched the bottom end of mine yet,but IMO, I don't think doing one side only is wise. With almost 800 hours,I would think a complete rebuild would be best. The other side more than likely has damage also.
As for used parts,not sure,but if you plan on keeping your tractor,I don't think that is a good idea either.
You can find the gaskets from alot of places,but I actually like dealing right from Onan for any part.Better price too.:)
Onanparts.com, Your Onan Parts Solution
Greg
/ 317 Onan p218 #10
agree with Greg. Installing used parts of unkown origin isnt going to save you much if it blows again.
/ 317 Onan p218
I just got done pricing the parts for a rebuild for my engine. The machine shop tells me that the crankshaft needs to be ground .020 to clear up the damage. The bearing costs are astronomical. Nearly 150.00 dollars for one bearing. No way am I going to pay that. If I can't find a cheaper source for parts. This thing is going in the junk pile and I'll find another engine, either new or used. I guess it's the American way to gouge a consumer with totally ridiculous prices when they think they can. By the way the bearing for the opposite end of the crank is only 50.00 bucks, go figure.
/ 317 Onan p218 #12
I have a 317 that I rebuilt after the Kohler Series 1 engine blew. I was able to find a series II short block on weekend freedom machines (google it) for about $800. It runs like a champ now. It probably wasn't worth the price but it wasn't just about the money :)
/ 317 Onan p218
I was trying to tell my brother it wasn't just the money. He would rather go to Lowes and buy a cheap knockoff of the real thing. Oh well, change the things you can and fix it when it breaks. I can't get it in my head to part out a good piece of equipment. Guess I'm just too old school.
/ 317 Onan p218 #14
That's the exact reason I put the time and money in redoing my 316.
That bearing price seems way out of line. Is that a quote from the machine shop?
Did you happen to email Onan and ask if they had oversized main bearings?
Greg
/ 317 Onan p218
I found a source for parts for the onan engine. So far I have spent a little over 600.00 dollars. I decided I would go ahead and rebuild it completely. New pistons ,rods bearings seals and the whole works. I could have bought a used engine for what I will have in it when I am finished, but the way I look at it better the devil you know. I have a 3520 that I use to do the big wide open mowing, and a 140 that I use for the trim work. The 317 was what I used before I bought the 3520. I installed the Onan engine in it after it threw a rod. A lot of people can't understand, but I can't seem to part with old equipment. I would rather repair old iron any day, but I am not adverse to modern equipment, hence the 3520. It's been the best purchase I've ever made but I don't it will last as long as my 140. Just my 2cents.
