316 Skip in Engine
/ 316 Skip in Engine #1
Firepuppy
Rome, NY
John Deere 316
Hi Fellows i need your help i replaced my points and condensor on my JD 316 Tractor with an Onan B43E engine hoping to eliminate a skip in the engine but it even does it with the news parts can anyone tell me if im missing something
thanks
Gene
/ 316 Skip in Engine #2
IME, I would double check the points, reset if they are off, start & run a little, check again. If they are still off, could be a cam bearing spun in the end plate.
Ed
/ 316 Skip in Engine #3
Have you ruled out a fuel issue? Or do you know the skip is a spark problem?
How long (duration) is the skip? What seems to cause it to recover? rpm? ??
well im pretty sure its not a fuel problem im leaning more tord a sparkplug wire it doesnt seam to fit tight but when its running i can hear it but it seems to go away i think when i turn on the pto
New/Unused CFG Industrial H15R Mini Excavator (A65583)
New/Unused CFG...
(1) HD 24ft Free Standing Corral Panel (A65579)
(1) HD 24ft Free...
Westerns 8.5 Pro Plus w/Quad, Ultra Mount 2 (A62679)
Westerns 8.5 Pro...
1994 CHEVROLET GMT-400 EXTENDED CAB TRUCK (A64280)
1994 CHEVROLET...
Bulk Lot - (3) Sticks HDPE Pipe - 24in x 40ft - Selling as One Lot (A63689)
Bulk Lot - (3)...
County Line 4' 3-Pt Rotary Mower (A66408)
County Line 4'...
