3131 *** NO START *** HELP
/ 3131 *** NO START *** HELP #1
michaelstowing
Adamsville
kubota 3131 x2
3130 with a no start. it will start on assisted fuel through the filter, and have to continue to add to keep running. i have the seat bypassed, it is flashing the letter A on the display.
Please help, we use this machine daily like it's our right hand.
Thanks
Michaels Automotive/Towing
/ 3131 *** NO START *** HELP #2
It sounds like its not getting fuel. I assume you mean assisted as in through the air filter using starter fluid? I'd check and make sure the lift pump is working. On some machines you can here it running if you turn the key to on. Also make sure you don't have a plugged up fuel filter.
/ 3131 *** NO START *** HELP #3
Check all fuses under dash and near battery. The A will flash in some test and setup modes not sure if their is a problem with the Intellipanel but you do need power to the run/stop solenoid to run on the L3130.
The Grand L3130 has a mechanical lift pump, you will not here the clicking like the BXs do.
PDF Workshop Manual
http://www.kubota.cz/data/manualy/l-30-wsm-en.pdf
David
/ 3131 *** NO START *** HELP #4
Yikes. Don't use starting fluid on a diesel. They tend to become addicted to it.
Ripper Tooth Excavator Attachment (A61572)
Ripper Tooth...
*Selling at Royal Auction Tampa, FL Location* (A59231)
*Selling at Royal...
ALLMAND NIGHT-LIT PRO II SERIES (INOPERABLE) (A63569)
ALLMAND NIGHT-LIT...
GLASS OVAL WINDOW (A63745)
GLASS OVAL WINDOW...
ELECTRIC MOTOR & FLOW MAX PUMP (A63290)
ELECTRIC MOTOR &...
John Deere 4710 Self Propelled Sprayer (A64047)
John Deere 4710...
