3131 *** NO START *** HELP
/ 3131 *** NO START *** HELP #1
michaelstowing
Adamsville
kubota 3131 x2
3130 with a no start. it will start on assisted fuel through the filter, and have to continue to add to keep running. i have the seat bypassed, it is flashing the letter A on the display.
Please help, we use this machine daily like it's our right hand.
Michaels Automotive/Towing
/ 3131 *** NO START *** HELP #2
It sounds like its not getting fuel. I assume you mean assisted as in through the air filter using starter fluid? I'd check and make sure the lift pump is working. On some machines you can here it running if you turn the key to on. Also make sure you don't have a plugged up fuel filter.
/ 3131 *** NO START *** HELP #3
Check all fuses under dash and near battery. The A will flash in some test and setup modes not sure if their is a problem with the Intellipanel but you do need power to the run/stop solenoid to run on the L3130.
The Grand L3130 has a mechanical lift pump, you will not here the clicking like the BXs do.
PDF Workshop Manual
http://www.kubota.cz/data/manualy/l-30-wsm-en.pdf
David
/ 3131 *** NO START *** HELP #4
Yikes. Don't use starting fluid on a diesel. They tend to become addicted to it.
2020 Hino 195 20ft. Electric Box Truck (A59230)
2020 Hino 195...
2017 TOYOTA TUNDRA(INOPERABLE) (A63569)
2017 TOYOTA...
10ft Cattle Panels (A64047)
10ft Cattle Panels...
2021 Ford F-150XL (A62180)
2021 Ford F-150XL...
2018 FORD F550 XL 6K LB SERVICE CRANE (A62613)
2018 FORD F550 XL...
Giyi Mini Land Leveler (A62183)
Giyi Mini Land...
