3130 100 Hour Service
   / 3130 100 Hour Service #1
SEC
Southeastern Oklahoma
Kubota L 3130 HST, 723 QA loader
I just performed my 100 Hour Service on my L3130. The Operator's Manual calls for 6 Quarts of oil with Filter Change. I changed Oil Filter and added 6 Quarts of oil, but now the dipstick shows that I have over filled by about a half quart of oil. I have started it up and let it run for about a minute, then let it sit overnight and recheck, but it still shows the same. This tractor has been flawless since day one and I don't want a leak to start now. Has anyone else had this problem?
   / 3130 100 Hour Service #2
My 3010 calls for 5.8 qts I believe. I thought they used the same engine in the 3130, but not positive. If that is the case it is not overfilled by much, and it would have to be a good bit too much for the crankshaft to hit the oil to cause it to foam. I don't think I would be concerned with it unless I saw air bubbles on the dipstick. Foaming could actually cause a loss of oil pressure and that would cause more damage than having a leak. I have "overfilled" on cars and trucks before by going 'by the book' and never had a problem.
   / 3130 100 Hour Service #3
I put 6 quarts in mine and its' full to the top line on the stick but not overly full. Are you sure all the oil was out? Was it sitting at a slight angle maybe?
Did you have the same issue at the 50 hour oil change?
The 50 hour service was performed by the dealer. When I brought it home I checked it and it was on the upper line. I'm a little concerned because my father in law bought a new Dodge with a Cummins deisel that had the wrong dip stick installed at the factory. When I changed the oil the tractor was in my shop on level ground and I let it drain from both drain plugs for two hours. I guess I will drain some out.
   / 3130 100 Hour Service #5
my 3010 also uses 5.8 qts Larry
   / 3130 100 Hour Service #6
When I change oil and filter on my 3130, 5.5 qts is the correct amount of oil to put it on the full mark.
Honda EU3000is Gasoline Companion Inverter Generators (A51691)
Honda EU3000is...
2014 TROXELL 130BBL VACUUM TRAILER (A53843)
2014 TROXELL...
UNUSED CFG INDUSTRIAL H15R EXCAVATOR (A52706)
UNUSED CFG...
METAL FILING CABINET (A53843)
METAL FILING...
2014 Ag Spray Schaben Sidedresser (A53472)
2014 Ag Spray...
1998 INTERNATIONAL 4700 4X2 LIQUID TRANSFER TRUCK (A51406)
1998 INTERNATIONAL...
