3110D - GPM?
   / 3110D - GPM? #1
Republic of Texas
Bronze Member
North East Texas
John Deere 850 - Yanmar 3110D
How many GPM does thw hydraulic pump put out on the 3110D?
I'm looking to add remotes & so I need to know which control valves to buy.
   / 3110D - GPM? #2
Hoye sells this pump for your tractor without power steering. Do you have power steering? I believe it is rated at 9cc. HYDRAULIC PUMP: Yanmar Tractor Parts I believe that translates to 5.7gpm at 2400rpm. Not sure whether your original pump puts out that much or not . I suspect it has a tag on it showing the cc's. Might take a look.
   / 3110D - GPM?
If I were to add more remotes & control valves, do the control valves have to be rated for 5.4 GPM?
Or, can I use a valve that is rated for higher GPM?
   / 3110D - GPM? #4
You can use one rated for higher. (8GPM I believe)I added a grapple valve. it works just fine. I think it's just saying it won't handle anymore than 8 GPM
   / 3110D - GPM?
Thanks kenmac!
Would you happen to have some pics & info on how you added the grapple?
   / 3110D - GPM? #7
If you click on Kenmac's name and then on his threads you can likely find them.
   / 3110D - GPM? #10
If I figured it out, anyone can. What loader do you have ? Does the loader valve have a PB port. You would have to be able to get a PB sleeve for the loader valve.
2007 Eager Beaver 35 GLB Lowboy, Tandem Axel (A52384)
2007 Eager Beaver...
Electric Forklift Pallet (A50322)
Electric Forklift...
2015 MAC FLATBED 48FT TRAILER (A52141)
2015 MAC FLATBED...
HAMM 3205 SMOOTH DRUM ROLLER (A51242)
HAMM 3205 SMOOTH...
2001 Ford F150 (A50121)
2001 Ford F150...
JOHN DEERE 850J LGP DOZER (A52472)
JOHN DEERE 850J...
