310D Aux Hydraulics
/ 310D Aux Hydraulics #1
95Backhoe
Renton, WA
John Deere 310D
I have a JD 310D backhoe with an aux hydraulics connection on the dipper. My question is what is the designed flow and pressure at the outlet port of the aux hydraulics?
I know the hydraulic system runs at 2700 psi and 38 gpm total flow, is that what the aux hydraulics runs at?
/ 310D Aux Hydraulics #2
The aux hydraulics run different pressures, I am not sure what the aux reliefs are set at. As far as the flow it should be the same. You might need to double check your system pressure because system pressure on that machine should be between 3200 to 3500 psi.
(6) 250 Gal Chemical Containers (A64127)
(6) 250 Gal...
Spartan RT-HD Zero Turn Mower (A66285)
Spartan RT-HD Zero...
2000 Ford Windstar Van (A64557)
2000 Ford Windstar...
New/Unused 3-in-1 Quick Attach Frame (A65583)
New/Unused 3-in-1...
1987 Kenworth T800 Day Cab (A62613)
1987 Kenworth T800...
2008 Ford F-550 4x4 Landscape Dump Truck with Lift Gate (A61568)
2008 Ford F-550...
