310 Problem
/ 310 Problem #1
MF283
Platinum Member
Lebanon, TN
JD 5303 JD 920M JD825I XUV Gator
I was checking fence rows yesterday & had part of a 2 trunk oak fallen into another tree, Go get the tractor & pulling rope, 310 & head back in the 90 degree plus heat.
Pull the fallen one out of the other tree, fire the 310 up, this thing sounds great , measure off my cuts, it's 40' long & straight.
All went well until i drain tank & try to start saw, rope pulls out & it sounds like something is stripped, no resistance. With the cover pulled, the rope feels good with a little resistance to it & rewinds great.
Once again, i'm after your Guru thought's on this problem, i'm thinking rewind spring before i get to involved, your thought's appreciated.
Ronnie
/ 310 Problem #2
Sounds like the spring that causes the starter pawl/engagement system to engage the gear on the flywheel has a broken part. Like you said - I would start with the rewind spring and go from there.
/ 310 Problem
The rewind spring wasn't broken, did notice a black part on the top side looked to be broken, going by the dealer in the morning to see if i can get it w/o having to buy the whole assembly.
Ronnie
/ 310 Problem
It woundup being the black pawl on top, a 2 dollar & change part. It took both the wife & i to get that blame spring re-wound, tried several times & got close on my own, the extra hands helped.
Now i need to decide if i need the 310 & 029 both being they are so close together in size.
Ronnie
2019 VOLVO A45G OFF ROAD DUMP TRUCK (A62129)
2019 VOLVO A45G...
5' Bush Hog (A62613)
2017 Ford E-Series FedEx Delivery Truck, 5.4L V8, Step Van Conversion (A63689)
2017 Ford E-Series...
New/Unused 3 Point Hitch with Ball/Flat Hitch (A65583)
New/Unused 3 Point...
Kubota V3300-T-E3BG Turbo Diesel Engine - 3.3L - 84 HP - 2018 - Tier 4 Interim (A63689)
Kubota...
Used 20' Container (A62679)
Used 20' Container...
